Element Animations
DaveOzric
DaveOzric posted this 13 July 2017
Hello, I often see some animations on various sites as you scroll down the page. Is there any method to do this with Themler outside of a slider?
If not can a slider be used for this but only have one slide?
And if that answer is yes how to you delay it until it becomes visible to the user? They all start when you scroll down and reach them not on page load.
Hello, I often see some animations on various sites as you scroll down the page. Is there any method to do this with Themler outside of a slider? If not can a slider be used for this but only have one slide? And if that answer is yes how to you delay it until it becomes visible to the user? They all start when you scroll down and reach them not on page load. Thank you
6 Comments
Support Team posted this 14 July 2017
You can set the animation to start on the ScrollLoop, that should work as you have explained.
Hi, You can set the animation to start on the `ScrollLoop`, that should work as you have explained. Sincerely, Hella
gcg
gcg posted this 14 July 2017
Hi Dave,
I use a third party extension for animations, and much more, its called Ultimate Shortcodes for Joomla > https://extensions.joomla.org/extension/shortcode-ultimate/ I use the pro version, one payment and have lifetime license and upgrades (via envato).
I use almost options of this extension in combination with Themler and the results are great.
Its really simple to use it. Have a Joomla editor plugin that add button on articles view.
Regards.
Hi Dave, I use a third party extension for animations, and much more, its called Ultimate Shortcodes for Joomla > https://extensions.joomla.org/extension/shortcode-ultimate/ I use the pro version, one payment and have lifetime license and upgrades (via envato). I use almost options of this extension in combination with Themler and the results are great. - Animation shortcodes > http://bdthemes.net/demo/joomla/shortcode/en/shortcodes/animation.html - Other shortcodes > http://bdthemes.com/demo/?product=shortcodeultimate Its really simple to use it. Have a Joomla editor plugin that add button on articles view. Regards.
DaveOzric
DaveOzric posted this 14 July 2017
Hello GCG, I will look at this more. I am truely trying to reduce the things I add to a site now days. It gets to be a lot of things to keep track of when you have all this.
Hella, is there any ideas on what animations you can use in Themler? I will try the scrolloop for loading.
Hello GCG, I will look at this more. I am truely trying to reduce the things I add to a site now days. It gets to be a lot of things to keep track of when you have all this. Hella, is there any ideas on what animations you can use in Themler? I will try the scrolloop for loading. Thanks
Support Team posted this 17 July 2017
I mean to set the desired type of animation under the Affect drop-down and the Launch option should be set to ScrollLoop under the enabled Animation settings.
Hi, I mean to set the desired type of animation under the Affect drop-down and the Launch option should be set to ScrollLoop under the enabled Animation settings. Sincerely, Hella
DaveOzric
DaveOzric posted this 17 July 2017
OK, thanks. I'll try some things and see what I find.
Much appreciated.
OK, thanks. I'll try some things and see what I find. Much appreciated.
You are welcome. Let us know if you need our further assistance.
You are welcome. Let us know if you need our further assistance. Sincerely, Hella
