How to style WooCommerce Search Results Page
sgertsos
sgertsos posted this 14 July 2017
I would like to know how can I style the products search result page in woocommerce.
Hello I would like to know how can I style the products search result page in woocommerce. Thank you
Support Team posted this 17 July 2017
There is a way to crate a new products template for products search result but this solution requires two conditions:
  1. woocommerce 3+
  2. you can only use Woocommerce Product Search widget. It does not work for Themler Search control. In case of Woocommerce Products search widget theme will use Themler Products template for search results.
To create alternative products template for search results please use the following solution:
  1. add new Products template in Themler and customize it:
  2. save theme >> open theme folder >> find /templates folder. You should see two files products_#.php files. You need the one created recently. Usually it has higher number. Remember this number.
  3. open Themler >> Settings >> CMS Code and add the following code:
    function template_chooser($template) {
    global $wp_query;
    $post_type = get_query_var('post_type');
    if ($wp_query->is_search && $post_type == 'product') {
    $template = locate_template('templates/products_10.php');
    return $template;
    add_filter('template_include', 'template_chooser');
    here products_10.php is the name of the file you searched in the /templates folder. Change the name to the name of the file from your theme.
Now if you serach for products from woocommerce search widget the search results page will use this new Products template which you can customize in the way you want.
Hi, There is a way to crate a new products template for products search result but this solution requires two conditions: 1. woocommerce 3+ 2. you can only use Woocommerce Product Search widget. It does not work for Themler Search control. In case of Woocommerce Products search widget theme will use Themler Products template for search results. To create alternative products template for search results please use the following solution: 1. add new Products template in Themler and customize it: !products-customize.png! 2. save theme >> open theme folder >> find `/templates` folder. You should see two files products_#.php files. You need the one created recently. Usually it has higher number. Remember this number. 3. open Themler >> Settings >> CMS Code and add the following code: `function template_chooser($template) { global $wp_query; $post_type = get_query_var('post_type'); if ($wp_query->is_search && $post_type == 'product') { $template = locate_template('templates/products_10.php'); } return $template; } add_filter('template_include', 'template_chooser');` here `products_10.php` is the name of the file you searched in the `/templates` folder. Change the name to the name of the file from your theme. Now if you serach for products from woocommerce search widget the search results page will use this new Products template which you can customize in the way you want. Thank you, Olivia
