margin and alignments
mptl.pharma
mptl.pharma posted this 14 July 2017
home page and header card - why/how come they have slightly different alignments ?
https://trinitydirect.com.au/index.php/tiles/floor-tiles/wood-look-floor-tiles.html
How do copy alignment of header to stay same to all pages ?
Also, How to I make sure all pages (product, home page. shopping cart), have same margin distance on both side of the screen ?
home page and header card - why/how come they have slightly different alignments ? https://trinitydirect.com.au/index.php/tiles/floor-tiles/wood-look-floor-tiles.html https://trinitydirect.com.au/index.php/ How do copy alignment of header to stay same to all pages ? Also, How to I make sure all pages (product, home page. shopping cart), have same margin distance on both side of the screen ?
Support Team posted this 14 July 2017
Please check the following option:
If it is enabled please disable it for testing.
Hi, Please check the following option: !home-page-style.png! If it is enabled please disable it for testing. Thank you, Olivia
mptl.pharma
mptl.pharma posted this 15 July 2017
tried that - where else settings could be ? Can you tell all relevant settings at once please ?
Support Team posted this 18 July 2017
Currently the links you provided do not demonstrate the issue.
Usually the issue with different style of the shared areas is related to the highlighted option, additional/wrong styles loaded on the specific pages, to the fact that in one of the cases Header is not Header, this could be caching issue also. These are general problems.
In your case, as I remember, the issue was related to the highlighted option according to the page source.
Hi, Currently the links you provided do not demonstrate the issue. Usually the issue with different style of the shared areas is related to the highlighted option, additional/wrong styles loaded on the specific pages, to the fact that in one of the cases Header is not Header, this could be caching issue also. These are general problems. In your case, as I remember, the issue was related to the highlighted option according to the page source. Thank you, Olivia
