v382 bugs
pdg.design
pdg.design posted this 15 July 2017
Hi. This a two bugs - what I see.
Firstly - in RTL Joomla - Blog category- Post image in Blog over to left alignment, and I can not to over it to right alignment (so option Position not worked me )
Second - Joomla Post image in Blog not linked, in 379 it was linked.
And I asked few times, in RTL - Joomla - Blog - Post - Layout - then I choose 2 columns and more please set columns in RTL and not in LTR (so, Layout must to be from Right to LEft)
Please add Hebrew fonts in Google Fonts.
Thank you!
Hi. This a two bugs - what I see. Firstly - in RTL Joomla - Blog category- Post image in Blog over to left alignment, and I can not to over it to right alignment (so option Position not worked me ) Second - Joomla Post image in Blog not linked, in 379 it was linked. And I asked few times, in RTL - Joomla - Blog - Post - Layout - then I choose 2 columns and more please set columns in RTL and not in LTR (so, Layout must to be from Right to LEft) Please add Hebrew fonts in Google Fonts. Thank you!
Support Team posted this 17 July 2017
We implemented joomla image floating support. Now you can set image floating under the article settings in joomla. Looks like the images have floating on your side. Eith set floating to none or change global floating settings:
It is still linked. The problem is that you're using floating. Looks like Post content overlaps the image. There are two ways to solve this issue:
  1. Post Image >> More Options >> set position to "relative" and zindex to "1"
  2. or open Post content >> More Options >> overflow set to "hidden".
We're using bootstrap grid system which does not adapted to RTL.
Google does not natively support Hebrew fonts. Currently they are Early Access, not officially supported:
https://fonts.google.com/earlyaccess
Hi, > Firstly - in RTL Joomla - Blog category- Post image in Blog over to left alignment, and I can not to over it to right alignment (so option Position not worked me ) We implemented joomla image floating support. Now you can set image floating under the article settings in joomla. Looks like the images have floating on your side. Eith set floating to none or change global floating settings: !joomal-image-floating.png! > Second - Joomla Post image in Blog not linked, in 379 it was linked. It is still linked. The problem is that you're using floating. Looks like Post content overlaps the image. There are two ways to solve this issue: 1. Post Image >> More Options >> set position to "relative" and zindex to "1" 2. or open Post content >> More Options >> overflow set to "hidden". > And I asked few times, in RTL - Joomla - Blog - Post - Layout - then I choose 2 columns and more please set columns in RTL and not in LTR (so, Layout must to be from Right to LEft) We're using bootstrap grid system which does not adapted to RTL. > Please add Hebrew fonts in Google Fonts. Google does not natively support Hebrew fonts. Currently they are Early Access, not officially supported: https://fonts.google.com/earlyaccess Thank you, Olivia
pdg.design
Is Solution
pdg.design posted this 17 July 2017
Thank you!
Thank you!
