I can not find the documentation for column--shortcodes
cogray
cogray posted this 17 July 2017
This link no longer shows the page that demonstrated how to use the column short codes for Joomla.
http://answers.themler.com/articles/3896/columns-shortcode
Where is that documentation?
This link no longer shows the page that demonstrated how to use the column short codes for Joomla. http://answers.themler.com/articles/3896/columns-shortcode Where is that documentation?
14 Comments
Support Team posted this 17 July 2017
This article is a little alb and re unpublished it.
Currently you don't need a shortcodde. If you want to add columns inside some article you can simply insert Columns control in the green content area of this specific page. Themler will automatically create shortcode.
Hi, This article is a little alb and re unpublished it. Currently you don't need a shortcodde. If you want to add columns inside some article you can simply insert Columns control in the green content area of this specific page. Themler will automatically create shortcode. Thank you, Olivia
DaveOzric
DaveOzric posted this 18 July 2017
Hmmm, can you explain this more? I am not following your instructions. I believe they are asking about a Joomla editor not in Themler. Maybe you can add some more editor buttons for Joomla's editor?!
> Hi, > > This article is a little alb and re unpublished it. > Currently you don't need a shortcodde. If you want to add columns inside some article you can simply insert Columns control in the green content area of this specific page. Themler will automatically create shortcode. > > Thank you, > Olivia Hmmm, can you explain this more? I am not following your instructions. I believe they are asking about a Joomla editor not in Themler. Maybe you can add some more editor buttons for Joomla's editor?!
Support Team posted this 18 July 2017
Hi Dave,
What is the difference? You can add Columns and style them in the way you need in Themler and get shortcode in the Joomla editor. It easier then creating of the shortcode manually.
Hi Dave, > . I believe they are asking about a Joomla editor not in Themler. What is the difference? You can add Columns and style them in the way you need in Themler and get shortcode in the Joomla editor. It easier then creating of the shortcode manually. Thank you, Olivia
DaveOzric
I do not understand what you are saying.
Say I want to add columns to a Joomla article. How is this done with you idea? Can you show me how you are doing this?
I do not understand what you are saying. Say I want to add columns to a Joomla article. How is this done with you idea? Can you show me how you are doing this?
Bayern
Bayern posted this 19 July 2017
open your article in Themler
insert columns - insert html - save
go to Joomal admin panel - open your article
open your article in Themler insert columns - insert html - save !1.png! go to Joomal admin panel - open your article !2.png!
Stagger Lee posted this 19 July 2017
It is no solution for Users who dont want to use Themler for content editing.
Bayern
This is for Joomla and can be edited there with every editor
DaveOzric
DaveOzric posted this 19 July 2017
Right, exactly, I do not want to open articles in Themler to add columns. We need a editor button that adds columns as a plugin.
Sometimes I may want to use Themler to add some fancy stuff but often I just need 2 columns and it's a pain to go through all that.
> It is no solution for Users who dont want to use Themler for content editing. > Right, exactly, I do not want to open articles in Themler to add columns. We need a editor button that adds columns as a plugin. Sometimes I may want to use Themler to add some fancy stuff but often I just need 2 columns and it's a pain to go through all that.
Support Team posted this 20 July 2017
I've updates shortcodes in the article and published it back.
But in any cause, it's easier to create specific article where you will insert controls in Themler to get shortcodes. Because Themler allows you to easily stylize the controls which will be converted to the shortcode instead of manual adding attributes. You can then copy shortcodes from this article into other articles or modules/widgets where shortcode processing is supported.
Hi, I've updates shortcodes in the article and published it back. But in any cause, it's easier to create specific article where you will insert controls in Themler to get shortcodes. Because Themler allows you to easily stylize the controls which will be converted to the shortcode instead of manual adding attributes. You can then copy shortcodes from this article into other articles or modules/widgets where shortcode processing is supported. Thank you, Olivia
cogray
cogray posted this 26 July 2017
Olivia,
Thank you for publishing this back.
I can't speak for everyone but for me I sell my services to prospects by telling them Joomla (or other CMS) allows them to edit the content themselves without technical knowledge. This is a big selling point. I've always felt that your targeted audience is more technical then my end-user. Your interface has greatly improve from our perspective but I would never let my customers edit content using your editor. Although it would probably allow me to make more money fixing all the things they break, I would loose them as clients. :-) On that note please never take away the ability to save the template without the Themler editor.
> Hi, > > I've updates shortcodes in the article and published it back. > But in any cause, it's easier to create specific article where you will insert controls in Themler to get shortcodes. Because Themler allows you to easily stylize the controls which will be converted to the shortcode instead of manual adding attributes. You can then copy shortcodes from this article into other articles or modules/widgets where shortcode processing is supported. > > Thank you, > Olivia Olivia, Thank you for publishing this back. I can't speak for everyone but for me I sell my services to prospects by telling them Joomla (or other CMS) allows them to edit the content themselves without technical knowledge. This is a big selling point. I've always felt that your targeted audience is more technical then my end-user. Your interface has greatly improve from our perspective but I would never let my customers edit content using your editor. Although it would probably allow me to make more money fixing all the things they break, I would loose them as clients. :-) On that note please never take away the ability to save the template without the Themler editor.
Support Team posted this 26 July 2017
Hi cogray,
Themler is a theme generator at first place. There are a lot of ready paid and free CMS visual content builders that you can use. We're also working on our own.
Hi cogray, Themler is a theme generator at first place. There are a lot of ready paid and free CMS visual content builders that you can use. We're also working on our own. Thank you, Olivia
DaveOzric
DaveOzric posted this 26 July 2017
I don't want Themler complicated with too much editing ability for basic users.
Bayern
Bayern posted this 26 July 2017
Thank you Olivia,
i fully agree with you
Thank you Olivia, i fully agree with you
copywriter
copywriter posted this 09 September 2019
Thank you very much for your article, I managed to fix an error after updating the template, when the plugin Thmeler-code stopped working and showed an error. I fully agree with you to rebuild the page with the column codes. This solution is not handy.
