Is themler for drupal 8 down?
yormedia
yormedia posted this 20 July 2017
Hi I get an empty page when going to edit theme.
Even with a clean Drupal 8 on server and bitnami.
enter image description here
Hi I get an empty page when going to edit theme. Even with a clean Drupal 8 on server and bitnami. ![enter image description here][1] [1]: http://attachments.answers.billiondigital.com/302/28302/Themler8Down.png
Support Team posted this 20 July 2017
Usually empty page means some error.
Could you please check server logs and enable error reporting so we can see what error the page returns.
Hi, Usually empty page means some error. Could you please check server logs and enable error reporting so we can see what error the page returns. Thank you, Olivia
yormedia
It is not only on the server. But also on a clean bitnami install with a clean theme
yormedia
Fixed, somehow permissions were changed on server. Still strange that it is not working on my bitnami install on windows machine.
Support Team posted this 21 July 2017
Unfortunately we cannot say anything without error message.
This could permissions issue or issue with php memory or upload/post limits or anything else.
In the following topic you mentioned issue with views:
http://answers.themler.com/questions/109941/drupal-8-beta-testing
Does the issue happen if you disable unique field module and clear cache?
Hi, Unfortunately we cannot say anything without error message. This could permissions issue or issue with php memory or upload/post limits or anything else. In the following topic you mentioned issue with views: http://answers.themler.com/questions/109941/drupal-8-beta-testing Does the issue happen if you disable unique field module and clear cache? Thank you, Olivia
