Drupal input control and tables
yormedia
yormedia posted this 26 July 2017
Maybe I am doing something wrong, but it seems Themler does not style my tables and input controls in drupal.
Anyone have this problem?
Hi, Maybe I am doing something wrong, but it seems Themler does not style my tables and input controls in drupal. Anyone have this problem?
Support Team posted this 31 July 2017
The default input and table styles can be set under the Design tab in Themler. If those styles then are not used in your pages, open that specific page inside Themler. Then click in the content to see the Posts control options on the top ribbon, go to Post Content >> More Styles and there check the styling for the table and input. If needed, press the Reset to default button in those options.
If the above suggestion does not help, provide an access to the site back end with several marked screen shots showing the issue in the control styling.
Hi, The default input and table styles can be set under the Design tab in Themler. If those styles then are not used in your pages, open that specific page inside Themler. Then click in the content to see the Posts control options on the top ribbon, go to Post Content >> More Styles and there check the styling for the table and input. If needed, press the Reset to default button in those options. If the above suggestion does not help, provide an access to the site back end with several marked screen shots showing the issue in the control styling. Sincerely, Hella
