Can you drag and drop sections?
alex487
alex487 posted this 29 July 2017
As you can see below I have 2 secions.. what if I want to swap the section 123 with 456.. whats the best way to do this? Can you drag n drop sections if you want to change to order as I want to do below?
enter image description here
As you can see below I have 2 secions.. what if I want to swap the section 123 with 456.. whats the best way to do this? Can you drag n drop sections if you want to change to order as I want to do below?![enter image description here][1] [1]: http://icepick.com/sections.png
shaulhadar
shaulhadar posted this 29 July 2017
Hi Alex, you need to open the left panel, there you will see all your sections and you can drag and drop upwards or downwards...
alex487
Ah I found it.. so it's that easy :)
Thanks!
Ah I found it.. so it's that easy :) Thanks!
