background images disappear when publishing
dpodesta
dpodesta posted this 29 July 2017
I have a problem with my site. When I save everything is fine, but if I publish the site, all background images disappear.
(index):339 GET **/css/images/designer/436760b3917598e018442f47c12fe933_a3817979654_16.jpg 404 (Not Found)
(index):339 GET **/css/images/designer/fd0a973e36413f8a18390ff9f9a83a94_title_marker3.png 404 (Not Found)
content-script-libs.js:3 GET **/css/images/designer/ce78427a7935737455308331d3b0bf4e_imagegalatatoweroptimised.jpg 404 (Not Found)
David
Hi I have a problem with my site. When I save everything is fine, but if I publish the site, all background images disappear. (index):339 GET **/css/images/designer/436760b3917598e018442f47c12fe933_a3817979654_16.jpg 404 (Not Found) (index):339 GET **/css/images/designer/fd0a973e36413f8a18390ff9f9a83a94_title_marker3.png 404 (Not Found) content-script-libs.js:3 GET **/css/images/designer/ce78427a7935737455308331d3b0bf4e_imagegalatatoweroptimised.jpg 404 (Not Found) David
Support Team posted this 30 July 2017
We;re aware about this issue and our developers are working on it. In the meantime you can solve it manually by saving theme (using Save option).
Hi, We;re aware about this issue and our developers are working on it. In the meantime you can solve it manually by saving theme (using Save option). Thank you, Olivia
dpodesta
dpodesta posted this 30 July 2017
great thanks
great thanks
yormedia
yormedia posted this 09 February 2018
Any update on this fix? Because it is still not publishing with images and icons in Drupal 8.
Support Team posted this 12 February 2018
Unfortunately I cannot provide you with the timeline for this fix in Drupal themes.
Hi, Unfortunately I cannot provide you with the timeline for this fix in Drupal themes. Thank you, Olivia
