Mac export.zip
artwebmaster2010
artwebmaster2010 posted this 01 August 2017
It's been several months that members have reported you a zip export problem under Mac.
On a topic you replied that the concern had been corrected.
I just installed the latest version of your app and it is with great regret that I discover that the problem has not been fixed.
PLEASE! Can you really solve this problem?
Pascal
Hello, It's been several months that members have reported you a zip export problem under Mac. On a topic you replied that the concern had been corrected. I just installed the latest version of your app and it is with great regret that I discover that the problem has not been fixed. PLEASE! Can you really solve this problem? Thanks Pascal
Support Team posted this 02 August 2017
Hello Pascal,
Is export possible for you, if you try to start Themler directly in a browser like Safari, Chrome or Firefox with the URL like http://127.0.0.1:29958/themler_XXXXXXXXXX/startup/ and then export? The exact numbers instead of XXXXXXXXXX can be specified if you run Live Preview in Themler - these are the numbers in browser address bar.
As a temporary solution, you may copy the theme manually from the folder with themes. Please click Go >> Go to Folder >> type ~/Library and ENTER >> Themler >> hd_data >> cms >> choose CMS and access the themes folder, copy the theme, zip it and install on your hosted website.
Hello Pascal, Is export possible for you, if you try to start Themler directly in a browser like Safari, Chrome or Firefox with the URL like http://127.0.0.1:29958/themler_XXXXXXXXXX/startup/ and then export? The exact numbers instead of XXXXXXXXXX can be specified if you run Live Preview in Themler - these are the numbers in browser address bar. As a temporary solution, you may copy the theme manually from the folder with themes. Please click Go >> Go to Folder >> type ~/Library and ENTER >> Themler >> hd_data >> cms >> choose CMS and access the themes folder, copy the theme, zip it and install on your hosted website. Sincerely, Nettie, BillionDigital Team
aaanupes
aaanupes posted this 19 October 2017
I do not understand any of those instructions
Support Team posted this 19 October 2017
aaanupes,
Could you please provide some more details about the issue in your case? Do you try to export from Themler for Mac as well or from Themler on your hosted website?
**aaanupes**, Could you please provide some more details about the issue in your case? Do you try to export from Themler for Mac as well or from Themler on your hosted website? Sincerely, Nettie, BillionDigital Team
