Import section and photos
jeanmarcvieux
jeanmarcvieux posted this 08 August 2017
Why cannot import joomla section or image from the library. It's disconnect me. The dialog box flash and then I'm disconnected. However I've themler pro purchased
Thank's
Hi, Why cannot import joomla section or image from the library. It's disconnect me. The dialog box flash and then I'm disconnected. However I've themler pro purchased Thank's Regards
artwebmaster2010
artwebmaster2010 posted this 08 August 2017
Hello Themler,
I have the same problem since this weekend.
Thanks for your help because it is no longer possible to work with the soft.
Pascal
Hello Themler, I have the same problem since this weekend. Thanks for your help because it is no longer possible to work with the soft. Pascal
Support Team posted this 08 August 2017
We are terribly sorry for the issue, our developers are working to solve it. Sorry again for the inconvenience.
Hi, We are terribly sorry for the issue, our developers are working to solve it. Sorry again for the inconvenience. Sincerely, Hella
Our developers reported that they fixed the issue with flashing login screen when you're trying to insert image or section.
Please try again and let us know the result.
Hi, Our developers reported that they fixed the issue with flashing login screen when you're trying to insert image or section. Please try again and let us know the result. Thank you, Olivia
jeanmarcvieux
Thanks a lot !!!!!
Thanks a lot !!!!!
You are welcome!
You are welcome! Sincerely, Nettie, BillionDigital Team
artwebmaster2010
artwebmaster2010 posted this 10 August 2017
Hello Themler,
Thanks!
Pascal
Hello Themler, Thanks! Pascal
Support Team posted this 10 August 2017
Pascal, you are welcome! Please feel free to contact us in any other case.
Pascal, you are welcome! Please feel free to contact us in any other case. Sincerely, Nettie, BillionDigital Team
