My post page alters logo and "home" url to "Blog"
Mike Kirk
Mike Kirk posted this 10 August 2017
When visiting a post, my logo and home URLs are different to the rest of the site. Rather than pointing to the home page they point to "/Blog".
Can this be fixed?
When visiting a post, my logo and home URLs are different to the rest of the site. Rather than pointing to the home page they point to "/Blog". Can this be fixed?
14 Comments
Support Team posted this 10 August 2017
What exactly CMS are you using?
The Logo control has a Link option on its tab in Themler. Please config the proper link and let us know the result.
Hi, What exactly CMS are you using? The Logo control has a Link option on its tab in Themler. Please config the proper link and let us know the result. Thank you, Olivia
Mike Kirk
Hello Olivia,
It is just a static html site.
The url for the logo looks to be correct inside Themler and it works on every other page. It is just when viewing the post in a browser that it forces "/Blog".
This directs to a 404 as that page does not exist.
Here is a screenshot of my logo url settings: https://i.imgur.com/Rg2VdEk.png
Kind regards,
Mike
Hello Olivia, It is just a static html site. The url for the logo looks to be correct inside Themler and it works on every other page. It is just when viewing the post in a browser that it forces "/Blog". This directs to a 404 as that page does not exist. Here is a screenshot of my logo url settings: https://i.imgur.com/Rg2VdEk.png Kind regards, Mike
Mike Kirk
My "home" menu button also takes you to /Bolg when viewing the post in the browser.
Mike Kirk
Mike Kirk posted this 11 August 2017
Any thoughts on this? Could really do with your help.
Kind regards,
Mike
Any thoughts on this? Could really do with your help. Kind regards, Mike
Support Team posted this 14 August 2017
Looks like your logo link is configured to go one page back from any page and that forces the Blog page to be opened when you press Logo on the post page. If you need the logo to go to the Home page, simply remove all the characters from the link option in the Logo settings.
Hi, Looks like your logo link is configured to go one page back from any page and that forces the Blog page to be opened when you press Logo on the post page. If you need the logo to go to the Home page, simply remove all the characters from the link option in the Logo settings. Sincerely, Hella
Mike Kirk
Mike Kirk posted this 14 August 2017
Hello Hella,
Thank you for your response.
Unfortunately this doesn't solve my problem. The reason "./" was used for the logo is because, when empty, the logo was always pointing to the current page url. E.g. the logo on the "about" page pointed to the "about" page.
Kind regards,
Mike
Hello Hella, Thank you for your response. Unfortunately this doesn't solve my problem. The reason "./" was used for the logo is because, when empty, the logo was always pointing to the current page url. E.g. the logo on the "about" page pointed to the "about" page. Kind regards, Mike
Please attach the theme exported with the editor included.
Hi, Please attach the theme exported with the editor included. Sincerely, Hella
Mike Kirk
Thank you Hella,
No Problem
Kind regards,
Mike
Thank you Hella, No Problem Kind regards, Mike
Mike Kirk
Mike Kirk posted this 15 August 2017
Hello Hella,
Should I assume it is best not to work on my theme until I hear from you?
Not sure if I will be importing the fixed theme or if fixes are made to themler?
Kind regards,
Mike
Hello Hella, Should I assume it is best not to work on my theme until I hear from you? Not sure if I will be importing the fixed theme or if fixes are made to themler? Kind regards, Mike
Support Team posted this 15 August 2017
In the attached theme the Link parameter is empty and I suggest you to enter the dull URL of the Home page that will be on the live site. So simply enter the domain name there.
Hi, In the attached theme the Link parameter is empty and I suggest you to enter the dull URL of the Home page that will be on the live site. So simply enter the domain name there. Sincerely, Hella
Mike Kirk
What about posts. Will the logo link still change to /blog?
Mike
What about posts. Will the logo link still change to /blog? Thanks, Mike
No, if you add the full static link, it will be working fine on any page.
Hi, No, if you add the full static link, it will be working fine on any page. Sincerely, Hella
Mike Kirk
I understand. I assume this may cause some issues in live preview. However, I am satisfied with this solution. Thank you, Hella, for your support.
Kind regards,
Mike
I understand. I assume this may cause some issues in live preview. However, I am satisfied with this solution. Thank you, Hella, for your support. Kind regards, Mike
You are welcome. Please feel free to contact us in any other occasion.
You are welcome. Please feel free to contact us in any other occasion. Sincerely, Hella
