Can create theme
webmaster@exnet.gr
webmaster@exnet.gr posted this 11 August 2017
I am opening the Thelmer on my desktop and I try to open Home page to edit it and It gets me to Page Not Found page. Are you aware of that? Is there any problem with Themler?
Thanks in advance
Hello, I am opening the Thelmer on my desktop and I try to open Home page to edit it and It gets me to Page Not Found page. Are you aware of that? Is there any problem with Themler? Thanks in advance
9 Comments
Support Team posted this 11 August 2017
What CMS do you create a new theme with?
Hello, What CMS do you create a new theme with? Sincerely, Nettie, BillionDigital Team
webmaster@exnet.gr
Joomla template
Joomla template
Could you please check that the source of the default menu item inside Joomla admin is set correctly. If that is the single article, check that the article exists. You can see how to set the default menu item under the Home tab here:
http://answers.themler.io/articles/36343/how-to-work-with-templates-in-joomla-themes
Hi, Could you please check that the source of the default menu item inside Joomla admin is set correctly. If that is the single article, check that the article exists. You can see how to set the default menu item under the Home tab here: http://answers.themler.io/articles/36343/how-to-work-with-templates-in-joomla-themes Sincerely, Hella
webmaster@exnet.gr
I am working local. I have no Joomla admin
webmaster@exnet.gr
On my computer. Last week i was working well. Now Now it only shows me the Not Fount page
You do have the Joomla admin as Themler works with the real sites. On the screen shot there is a Joomla sign on the top ribbon (third from the right side). Press it and you will access the admin panel.
Hi, You do have the Joomla admin as Themler works with the real sites. On the screen shot there is a Joomla sign on the top ribbon (third from the right side). Press it and you will access the admin panel. Sincerely, Hella
webmaster@exnet.gr
How the default settings changed from last week? As I told you it was working great.
webmaster@exnet.gr
Thank you. I have sold the problem
Nice to hear that, feel free to contact us in any other occasion.
Hi, Nice to hear that, feel free to contact us in any other occasion. Sincerely, Hella
