Create New Section but bad positions why???
stephane.fonteyne
stephane.fonteyne posted this 22 August 2017
Dear Support,
I would like to design 2 sections that i possess with Themler. I've already tried but i can clearly see that all components are badly alligned cause i can't see it on either smartphone, laptop or tablet screen.
Could someone cincerely help me on how to work with it and to send the result back to me so that i can take a look for myself and let Themler do the rest.
I'm sending the project in the appendix to you and help me with the 2 project sections which i sent in the last post to you as appendix.
My Project:
https://www.dropbox.com/s/fftopayem33ab4r/Elektricien2_my_projects_with_errors.zip?dl=0
Cincerely Stephane
Dear Support, I would like to design 2 sections that i possess with Themler. I've already tried but i can clearly see that all components are badly alligned cause i can't see it on either smartphone, laptop or tablet screen. Could someone cincerely help me on how to work with it and to send the result back to me so that i can take a look for myself and let Themler do the rest. I'm sending the project in the appendix to you and help me with the 2 project sections which i sent in the last post to you as appendix. My Project: https://www.dropbox.com/s/fftopayem33ab4r/Elektricien2_my_projects_with_errors.zip?dl=0 Cincerely Stephane
eneg
eneg posted this 24 August 2017
Hi I check your zip, you have to delete the columns and put first a empty section after put inside columns.
After that inside the column put a container, inside the container put a icon and text , the text align for right then left.
You have work with the moviles. In themler look up there's the icons for laptops, phones, etc.. click each icon and set the width for columns maybe also you will need to set the width section, try with auto option
for the footer just put section there the color have to be like orange
Hi I check your zip, you have to delete the columns and put first a empty section after put inside columns. After that inside the column put a container, inside the container put a icon and text , the text align for right then left. You have work with the moviles. In themler look up there's the icons for laptops, phones, etc.. click each icon and set the width for columns maybe also you will need to set the width section, try with auto option for the footer just put section there the color have to be like orange
stephane.fonteyne
stephane.fonteyne posted this 25 August 2017
Can you post the solution for the sections:
section-footer-1-contact-information
section-footer-2-copyright-social-icons
So I don't understand what you main
Stephane
Hi, Can you post the solution for the sections: section-footer-1-contact-information section-footer-2-copyright-social-icons So I don't understand what you main Thanks Stephane
Support Team posted this 29 August 2017
stephane.fonteyne,
We already answered you in your private topic.
You can search for the existing sections similar to the ones you need in Themler library and adjust them in the way you need (change Text control to Search, change colors, etc).
stephane.fonteyne, We already answered you in your private topic. You can search for the existing sections similar to the ones you need in Themler library and adjust them in the way you need (change Text control to Search, change colors, etc). Thank you, Olivia
