How to use Multiple Animations in Slider ?
Web IT Solutions LLP
Web IT Solutions LLP posted this 26 August 2017
Dear Sir,
Greetings!!!
I just like to know couple of queries which is very important to know how it actually can be achieved,
1) Can we use multiple Animation in Slider (Effects -> Animations -> Launch On = Slide In with two animations with slight Duration & Delay). ?
2) I tried two animations with Slide In with different duration & delay but it's not functioning. Could you please let us know is there any limitation like we cannot use more than one Launch On for particular Effect etc?
3) How to create more than 1 "Launch On" with "Slide In" effects Animation for Slider?
Suffian Ahmed
Dear Sir, Greetings!!! I just like to know couple of queries which is very important to know how it actually can be achieved, 1) Can we use multiple Animation in Slider (Effects -> Animations -> Launch On = Slide In with two animations with slight Duration & Delay). ? 2) I tried two animations with Slide In with different duration & delay but it's not functioning. Could you please let us know is there any limitation like we cannot use more than one Launch On for particular Effect etc? 3) How to create more than 1 "Launch On" with "Slide In" effects Animation for Slider? Regards Suffian Ahmed
10 Comments
Support Team posted this 30 August 2017
Sorry for the delay. What exactly effect are you trying to achieve? You can assign different animations to element on Slide In and Slide Out with or without delay. But you cannot assign two Slide In animations to the same control. The second duplicated Slide In animation will not be executed.
Hi, Sorry for the delay. What exactly effect are you trying to achieve? You can assign different animations to element on Slide In and Slide Out with or without delay. But you cannot assign two Slide In animations to the same control. The second duplicated Slide In animation will not be executed. Thank you, Olivia
Web IT Solutions LLP posted this 30 August 2017
Dear Mr. Olivia,
Greetings!!!
Demo Link - http://demo.webnoesys.in/home.html
Please find the screenshot attached, I have the slider on the main page, and I like to have 2 animations for the text control - "WELCOME TO LAUNDRY POINT" on Slide In with a different delay.
Animation -> Launch On -> Slide In & Effect -> Fade In (Duration - 1000ms & Delay 300 ms)
Animation -> Launch On -> Slide In & Effect -> Bounce (Duration - 1400ms & Delay 500ms)
About, both Animation for single control is for Slide In with two different Effects. I need both effects need to execute on Slide In for particular Slider Single Control.
Both animations need to execute it with slide delay, but it's not happening right now. Please provide the step by step process to achieve the same at the earliest.
Sorry for the delay & Appreciate your quick support from your side.
Thanks in advance, waiting for your valuable reply,
Suffian Ahmed
Dear Mr. Olivia, Greetings!!! Demo Link - http://demo.webnoesys.in/home.html Please find the screenshot attached, I have the slider on the main page, and I like to have 2 animations for the text control - "WELCOME TO LAUNDRY POINT" on Slide In with a different delay. Animation -> Launch On -> Slide In & Effect -> Fade In (Duration - 1000ms & Delay 300 ms) Animation -> Launch On -> Slide In & Effect -> Bounce (Duration - 1400ms & Delay 500ms) About, both Animation for single control is for Slide In with two different Effects. I need both effects need to execute on Slide In for particular Slider Single Control. Both animations need to execute it with slide delay, but it's not happening right now. Please provide the step by step process to achieve the same at the earliest. Sorry for the delay & Appreciate your quick support from your side. Thanks in advance, waiting for your valuable reply, Regards Suffian Ahmed
And, along with this above query, I need one more Animation support.
Mouse Hover effects are there, but could you please let us know how to make Hover In Animation & Hover Out Animation effect for the same Effects or different effects in Animation process with out any additional CSS & Java Script.
If not there, let us know the alternative for the same.
I need Hover In & Hover Out Effect for All Animations... How to achieve it?
Suffian Ahmed
And, along with this above query, I need one more Animation support. Mouse Hover effects are there, but could you please let us know how to make Hover In Animation & Hover Out Animation effect for the same Effects or different effects in Animation process with out any additional CSS & Java Script. If not there, let us know the alternative for the same. I need Hover In & Hover Out Effect for All Animations... How to achieve it? Regards Suffian Ahmed
Support Team posted this 31 August 2017
As mentioned in my previous reply you cannot assign two Slide In animations to the specific control. The second one will not work. This is behavior by default. However, you can put this control into Container, for example, and assign one of the animations to this Container (a Bounce, for example). This should make the trick.
Unfortunately Themler does not support Hover Out animations and there is no way to achieve it using Themler tools. You should implement it manually. But this requires at least basic css/html/js knowledge. In this case you will need to add own Hover In and Out animations. There are a lot of ready examples in the internet.
Hi, > About, both Animation for single control is for Slide In with two different Effects. I need both effects need to execute on Slide In for particular Slider Single Control. As mentioned in my previous reply you cannot assign two Slide In animations to the specific control. The second one will not work. This is behavior by default. However, you can put this control into Container, for example, and assign one of the animations to this Container (a Bounce, for example). This should make the trick. Unfortunately Themler does not support Hover Out animations and there is no way to achieve it using Themler tools. You should implement it manually. But this requires at least basic css/html/js knowledge. In this case you will need to add own Hover In and Out animations. There are a lot of ready examples in the internet. Thank you, Olivia
Web IT Solutions LLP posted this 06 September 2017
Dear Olivia,
Sorry to say, can we make container static and stable while the slider flows...
1) And how to make it full width, it's not appearing on top or at desired position with full width.
Could you please help us to make it possible, step by step what we need to do it please.
2) One more point, can we get more animations in Themler ? For all controls including Slider...
Check wowslider.com for your reference.
3) Can we get page controls for static HTML Website ? If yes, how to achieve it. It's there for CMS / WordPress websites but not available for HTML Website projects. I tried adding it but it say it's not available for your HTML Website. Why ?
4) Like testimonial, infinite slides can we get Image slider with multiple images flows in one direction slowly like Marquee infinite sliding images gallery ??? How to make it possible right now ? Any possible solution please ?
5) Any news about your new product release apart from Themler... I came to know that your team is working on new product tool, what's that and when can we get news. Is that upgrade version of Artisteer itself to competent Themler tool ?
Hope you answer all my humble queries...
Thanks in advance,
Suffian Ahmed
Dear Olivia, Sorry to say, can we make container static and stable while the slider flows... 1) And how to make it full width, it's not appearing on top or at desired position with full width. Could you please help us to make it possible, step by step what we need to do it please. 2) One more point, can we get more animations in Themler ? For all controls including Slider... Check wowslider.com for your reference. 3) Can we get page controls for static HTML Website ? If yes, how to achieve it. It's there for CMS / WordPress websites but not available for HTML Website projects. I tried adding it but it say it's not available for your HTML Website. Why ? 4) Like testimonial, infinite slides can we get Image slider with multiple images flows in one direction slowly like Marquee infinite sliding images gallery ??? How to make it possible right now ? Any possible solution please ? 5) Any news about your new product release apart from Themler... I came to know that your team is working on new product tool, what's that and when can we get news. Is that upgrade version of Artisteer itself to competent Themler tool ? Hope you answer all my humble queries... Thanks in advance, Regards Suffian Ahmed
Support Team posted this 07 September 2017
Unfortunately the issue and question about Container is not quite clear to me. Could you please describe it in more details including screenshots?
2.Unfortunately you cannot add more animations in Themler. The only way is to use custom coding.
3.What exactly page controls are you referring to?
HTML themes support only static HTML controls. All CMS specific PHP control cannot be added to HTML themes.
4.Could you please provide us with a link to the page with example?
But most probably it is not possible to create something like this using Themler built in tools. But you can add custom html/css/js into the HTML control to create anything you want.
5.The new tool is a simple and easy to use page builder and theme generator. Currently we're working on it and unfortunately I cannot provide you with the release bate yet. It's coming soon.
Hi, Unfortunately the issue and question about Container is not quite clear to me. Could you please describe it in more details including screenshots? 2.Unfortunately you cannot add more animations in Themler. The only way is to use custom coding. 3.What exactly page controls are you referring to? HTML themes support only static HTML controls. All CMS specific PHP control cannot be added to HTML themes. 4.Could you please provide us with a link to the page with example? But most probably it is not possible to create something like this using Themler built in tools. But you can add custom html/css/js into the HTML control to create anything you want. 5.The new tool is a simple and easy to use page builder and theme generator. Currently we're working on it and unfortunately I cannot provide you with the release bate yet. It's coming soon. Thank you, Olivia
Web IT Solutions LLP posted this 07 September 2017
Dear Mr. Olivia,
Thanks for your valuable quick reply, appreciate your time. We will reply the details if needed anything regarding the same...
And, could you please let us know the below point,
A) Is that above tool is free or payed... For your existing customers. ?
B) And, what's the difference between Themler & new tool ?
C) If it's addon or depends on Themler tool. Is that work on Themler web pages designing ?
D) It's for static HTML pages design or CMS etc ?
Lots of eagerness we have, please share your short & sweet reply :-)
We really feel happy as you answer our questions...
Regarding
Suffian Ahmed
Dear Mr. Olivia, Thanks for your valuable quick reply, appreciate your time. We will reply the details if needed anything regarding the same... And, could you please let us know the below point, 5.The new tool is a simple and easy to use page builder and theme generator. Currently we're working on it and unfortunately I cannot provide you with the release bate yet. It's coming soon. A) Is that above tool is free or payed... For your existing customers. ? B) And, what's the difference between Themler & new tool ? C) If it's addon or depends on Themler tool. Is that work on Themler web pages designing ? D) It's for static HTML pages design or CMS etc ? Lots of eagerness we have, please share your short & sweet reply :-) We really feel happy as you answer our questions... Regarding Suffian Ahmed
Support Team posted this 08 September 2017
The new tool is a new standalone tool. It has own framework and it is not compatible with Themler. It is close to Artisteer by its structure, than to Themler.
We have not yet approved a policy of licensing. We plan to make it paid but most probably we'll offer a discount for Themler users.
The new tool will work with WP, Joomla and will create static HTML websites.
Hi, The new tool is a new standalone tool. It has own framework and it is not compatible with Themler. It is close to Artisteer by its structure, than to Themler. We have not yet approved a policy of licensing. We plan to make it paid but most probably we'll offer a discount for Themler users. The new tool will work with WP, Joomla and will create static HTML websites. Please keep us posted about the progress. Thank you, Olivia
Web IT Solutions LLP posted this 16 October 2017
Dear Olivia,
Can you let us know any updates on new tool release dates beta version too...
Suffian Ahmed
Dear Olivia, Can you let us know any updates on new tool release dates beta version too... Regards Suffian Ahmed
Support Team posted this 17 October 2017
Unfortunately we cannot provide you with the release date yet. But Beta version in trial mode is already available on upage.io
Hi, Unfortunately we cannot provide you with the release date yet. But Beta version in trial mode is already available on upage.io Thank you, Olivia
