Artisteer / Themler buttons settings
johann9
johann9 posted this 04 September 2017
Trust you are well!
We use the Joomla Eshop component instead of Virtuemart.
When we create a template using Artisteer, the button settings is also applied to Eshop and is perfect, but when using Themler, it is not the case.
Is there a way that I could hack the code or make any changes to update Eshops buttons as well?
I have attached two screen shots indicating the same website with the two templates
Trust you are well! We use the Joomla Eshop component instead of Virtuemart. When we create a template using Artisteer, the button settings is also applied to Eshop and is perfect, but when using Themler, it is not the case. Is there a way that I could hack the code or make any changes to update Eshops buttons as well? I have attached two screen shots indicating the same website with the two templates
Support Team posted this 05 September 2017
Looks like the component uses the default button styles, for Artisteer that is indeed the default style from the theme. But in Themler it is the Bootsrap default style as our themes are based on Bootstrap. We can try to add the custom CSS code to style the button as your current button style from the theme. But in this case you will need to update those styles each time you change the styles in the the theme. For that we need a link to the page where you have your buttons and also the link to the page where there is a button styled correctly.
Hi, Looks like the component uses the default button styles, for Artisteer that is indeed the default style from the theme. But in Themler it is the Bootsrap default style as our themes are based on Bootstrap. We can try to add the custom CSS code to style the button as your current button style from the theme. But in this case you will need to update those styles each time you change the styles in the the theme. For that we need a link to the page where you have your buttons and also the link to the page where there is a button styled correctly. Sincerely, Hella
johann9
johann9 posted this 05 September 2017
Thanks - here is the eshop default button link:
http://ipopengfs.bloem-online.co.za/products/glue-tapes
and here is a page with the custom button
http://ipopengfs.bloem-online.co.za/index.php
The button I am referring to is under the "Good Service" section a bit lower on the page
Thanks, Johann
Thanks - here is the eshop default button link: http://ipopengfs.bloem-online.co.za/products/glue-tapes and here is a page with the custom button http://ipopengfs.bloem-online.co.za/index.php The button I am referring to is under the "Good Service" section a bit lower on the page Thanks, Johann
Support Team posted this 07 September 2017
Both buttons are using the Bootstrap styles. The difference is that in the shop the simple primary button is used and the custom button is a Danger button. You can style the primary button styling in Themler to be the same as the danger button.
Hi, Both buttons are using the Bootstrap styles. The difference is that in the shop the simple primary button is used and the custom button is a Danger button. You can style the primary button styling in Themler to be the same as the danger button. Sincerely, Hella
johann9
johann9 posted this 07 September 2017
Awesome - thanks for taking the time to investigate Hella!
Johann
Awesome - thanks for taking the time to investigate Hella! Johann
You are welcome. Let me know if you need further help.
You are welcome. Let me know if you need further help. Sincerely, Hella
