Copy wp theme to another site
paulogeada
paulogeada posted this 08 September 2017
I want to copy a theme I worked online to another domain.
had instaled the wp and imported the theme.
Ativated the themler tools.
When I try to import the content it gives a error: 'Error occured: (status 500)'
Another question:
How to import the content I worked online to local?
I want to copy a theme I worked online to another domain. had instaled the wp and imported the theme. Ativated the themler tools. When I try to import the content it gives a error: 'Error occured: (status 500)' Another question: How to import the content I worked online to local?
Support Team posted this 08 September 2017
Please try to check the "Include Content" box while exporting the theme, and then after installing the theme select Add or Replace Content.
Or do you need to import content only and not the theme with content?
It works in both directions - you may export the theme installed online with content (Export ZIP >> check Include Content), or export content from this theme using Export option.
Hello, Please try to check the "Include Content" box while exporting the theme, and then after installing the theme select Add or Replace Content. Or do you need to import content only and not the theme with content? It works in both directions - you may export the theme installed online with content (Export ZIP >> check Include Content), or export content from this theme using [Export][1] option. Sincerely, Nettie, BillionDigital Team [1]: http://answers.themler.io/articles/72522/import-export-content
