Virtuemart, change image zoom position in product
ideosiete
ideosiete posted this 11 September 2017
Hello, i want know if is possible change the image zoom position in the virtuemart product, because appear in left or right side. i want put it like this SAMPLE exist some place to configurate it?
Hello, i want know if is possible change the image zoom position in the virtuemart product, because appear in left or right side. i want put it like this [SAMPLE][1] exist some place to configurate it? [1]: http://www.norbac3.com/index.php/es/catalogo/suministro-mro/tapetes-ergon%C3%B3micos-anti-fatiga/wearwell/tapetes-%C3%A1reas-de-trabajo-pesado/ergodeck-smooth-detail
Support Team posted this 12 September 2017
No, there is no possibility in the application to control the cloud zoom positioning.
Hi, No, there is no possibility in the application to control the cloud zoom positioning. Sincerely, Hella
ideosiete
ideosiete posted this 12 September 2017
OK. I see, another question is. i can change this in some part when i export the themplate?
Support Team posted this 13 September 2017
As a workaround you can try removing Themler Product image and replacing it with CMS Code control where you output product image using custom code from the VM source files. In this case you can use third-party plugins to achieve the described zoom behavior. But in this case you will not be able to style this image in Themler and it will not be linked to Themler Product Thumbnails control.
Unfortunately Themler Could Zoom behavior cannot be adjusted manually as it will require global code rewriting.
Hi, As a workaround you can try removing Themler Product image and replacing it with CMS Code control where you output product image using custom code from the VM source files. In this case you can use third-party plugins to achieve the described zoom behavior. But in this case you will not be able to style this image in Themler and it will not be linked to Themler Product Thumbnails control. Unfortunately Themler Could Zoom behavior cannot be adjusted manually as it will require global code rewriting. Thank you, Olivia
