What do the add content options mean
jonathan44
jonathan44 posted this 12 September 2017
Please see image. What do these options mean under import content? If I click each one, what will happen?
  1. Add content: Does this mean I will add content while I'm designing?
  2. Replace imported content: Replace what imported content? It's a new website? Replace it with content I add to the theme?
I'm a bit confused.
Hi, Please see image. What do these options mean under import content? If I click each one, what will happen? 1. Add content: Does this mean I will add content while I'm designing? 2. Replace imported content: Replace what imported content? It's a new website? Replace it with content I add to the theme? I'm a bit confused. [1]: https://i.imgur.com/4A2z4mH.png
Support Team posted this 13 September 2017
There is no image attached, but I assume that you are talking about the options that appear when you import the theme in Themler. The Add Content button will add the content that was included in that theme while exporting. It will not replace the existing content of your current theme. The Replace Imported Content option will remove the old content of your theme and add the content from this imported template only.
That is not related to the design, it will remain the one imported from the new theme.
Hi, There is no image attached, but I assume that you are talking about the options that appear when you import the theme in Themler. The Add Content button will add the content that was included in that theme while exporting. It will not replace the existing content of your current theme. The Replace Imported Content option will remove the old content of your theme and add the content from this imported template only. That is not related to the design, it will remain the one imported from the new theme. Sincerely, Hella
