Changing Woocommerce 'Out of Stock' text
mrvargo
mrvargo posted this 13 September 2017
Hi. I'm trying to change the out of stock notice which appears on the thumbnail in Woocommerce product category display. I've inserted the following code (and a few variations) into functions-additional.php but it has no effect. Does anyone have a solution for this? Thanks
add_filter('woocommerce_get_availability', 'availability_filter_func');
function availability_filter_func($availability)
$availability['availability'] = str_ireplace('Out of stock', 'Sold', $availability['availability']);
return $availability;
Hi. I'm trying to change the out of stock notice which appears on the thumbnail in Woocommerce product category display. I've inserted the following code (and a few variations) into **functions-additional.php** but it has no effect. Does anyone have a solution for this? Thanks add_filter('woocommerce_get_availability', 'availability_filter_func'); function availability_filter_func($availability) { $availability['availability'] = str_ireplace('Out of stock', 'Sold', $availability['availability']); return $availability; }
Support Team posted this 13 September 2017
Do you mean that you vant to change the text of the Out of Stock control? In this case please try adding the following code to the Themler Settings >> CMS Code:
add_filter( 'gettext', 'wps_translate_words_array' );
add_filter( 'ngettext', 'wps_translate_words_array' );
function wps_translate_words_array( $translated ) {
  $words = array(
    // 'word to translate' = > 'translation'
    'Out of Stock' => 'YOUR_TRANSLATION',
$translated = str_ireplace( array_keys($words), $words, $translated );
return $translated;
This should help.
Hi, Do you mean that you vant to change the text of the Out of Stock control? In this case please try adding the following code to the Themler Settings >> CMS Code: add_filter( 'gettext', 'wps_translate_words_array' ); add_filter( 'ngettext', 'wps_translate_words_array' ); function wps_translate_words_array( $translated ) { $words = array( // 'word to translate' = > 'translation' 'Out of Stock' => 'YOUR_TRANSLATION', ); $translated = str_ireplace( array_keys($words), $words, $translated ); return $translated; } This should help. Thank you, Olivia
mrvargo
mrvargo posted this 14 September 2017
That did the trick! Thanks very much
Support Team posted this 14 September 2017
