image sharing for Facebook
hashem.mitug
hashem.mitug posted this 1 weeks ago
hi
I have a plugin called AddToAny Share Buttons
It should pull an image from the page and add it to share on Facebook
What am I doing wrong?
I want the image from the gallery to be in place when I share the page link https://ibb.co/hJm4ZF
https://ibb.co/czsp1v
hi I have a plugin called AddToAny Share Buttons It should pull an image from the page and add it to share on Facebook What am I doing wrong? I want the image from the gallery to be in place when I share the page link https://ibb.co/hJm4ZF https://ibb.co/czsp1v Thanks
9 Comments
Does it work fine with the default non-Themler theme?
Hi, Does it work fine with the default non-Themler theme? Sincerely, Hella
hashem.mitug
how do I do it
how do I do it
I assume that you are working with the WP theme. In this case you can activate the default WP Twenty theme and see how the sharing module works then.
Hi, I assume that you are working with the WP theme. In this case you can activate the default WP Twenty theme and see how the sharing module works then. Sincerely, Hella
hashem.mitug
hashem.mitug posted this 6 days ago
I do not know how to do it
You just need to open Themes menu in WP (should be under Appearance tab) and activate any non-Themler theme, e.g. Twenty Seventeen or similar.
Please let us know the result then.
Ivan
Hi, You just need to open **Themes** menu in WP (should be under Appearance tab) and activate any non-Themler theme, e.g. Twenty Seventeen or similar. Please let us know the result then. Thanks, Ivan
hashem.mitug
I did not have templates there so I installed the Twenty Seventeen template
And I confirmed it
I went back to themler and nothing changed
I did not have templates there so I installed the Twenty Seventeen template And I confirmed it I went back to themler and nothing changed
Sorry for the delay. So when you activated the Twenty Sewenteen theme the Facebook sharing was working fine or no? It's not clear from your last response. We need to know it to understand if the problem is related to the theme or some plug-in functionality.
Hi, Sorry for the delay. So when you activated the Twenty Sewenteen theme the Facebook sharing was working fine or no? It's not clear from your last response. We need to know it to understand if the problem is related to the theme or some plug-in functionality. Sincerely, Hella
hashem.mitug
hashem.mitug posted this 2 days ago
It did not work on this pattern either
Support Team posted this yesterday
If it does not work with the default WP theme then it is something wrong with the plugin or its configuration.
Hi, If it does not work with the default WP theme then it is something wrong with the plugin or its configuration. Thank you, Olivia
