Image size in Woocommerce shop view
hovmedia
hovmedia posted this 14 September 2017
Hi!
Please take a look at http://www.varselbutikken.no/produktkategori/skilt/bygg-anlegg/. Some images that are not in square shape are not fully visible. Can I set ut themler to shrink the image so it is visible inside the square?
And vertical menu are also visible trough "sticky header" while scrolling.
Hi! Please take a look at http://www.varselbutikken.no/produktkategori/skilt/bygg-anlegg/. Some images that are not in square shape are not fully visible. Can I set ut themler to shrink the image so it is visible inside the square? And vertical menu are also visible trough "sticky header" while scrolling.
Support Team posted this 15 September 2017
Looks like images are cropped to that square size by the CMS component used to add them. You can test with another theme to see if the issue persists.
As for the vertical menu overlap issue, please go to the Sticky extensions options of your Header and set the z-index property to 10000.
Hi, Looks like images are cropped to that square size by the CMS component used to add them. You can test with another theme to see if the issue persists. As for the vertical menu overlap issue, please go to the Sticky extensions options of your Header and set the z-index property to 10000. Sincerely, Hella
hovmedia
hovmedia posted this 16 September 2017
Tested another theme, same issue. Used Woocommerce to add images.
Support Team posted this 18 September 2017
I've visited your website and as I can see both issues are fixed now.
Please let us know if you need our further assistance here.
Hi, I've visited your website and as I can see both issues are fixed now. Please let us know if you need our further assistance here. Thank you, Olivia
