thumbnail in blog view link to articlein joomla
jeanmarcvieux
jeanmarcvieux posted this 23 September 2017
My question might be stupid but, I don't found how to link the thumbnail image in a blog view to the article.
The post header in linked to the article, ok
But i want the image too.
Thanks for helping me.
Hi, My question might be stupid but, I don't found how to link the thumbnail image in a blog view to the article. The post header in linked to the article, ok But i want the image too. Thanks for helping me.
Support Team posted this 25 September 2017
The Post Image on Blog Template is linked to the article too. In some cases when the Post Image control has floating positioning (Positioning >> Float Left or Right) it may not be clickable because Post Content Control is located on top of the image. To solve this issue you need to either reset the Post Image positioning or set Post Content "overflow" property to "hidden" under the Arrange section.
We can check the issue on your side if you provide a link to the page that demonstrates the issue.
Hi, The Post Image on Blog Template is linked to the article too. In some cases when the Post Image control has floating positioning (Positioning >> Float Left or Right) it may not be clickable because Post Content Control is located on top of the image. To solve this issue you need to either reset the Post Image positioning or set Post Content "overflow" property to "hidden" under the Arrange section. We can check the issue on your side if you provide a link to the page that demonstrates the issue. Thank you, Olivia
angelestuardo
angelestuardo posted this 07 October 2017
Thanks, I had the same problem, with your help I can fix it.
jeanmarcvieux
jeanmarcvieux posted this 08 October 2017
Just choose a model in blog mode in the window on the left and all articles in the blog are linked.
