Zoom Menu
stryjek-www
stryjek-www posted this 25 September 2017
Witam chciałbym na swojej stronie https://lasminet.com zrobić podobne menu jak na tej stronie http://skp.vcentrum.pl , chodzi mi o efekt pomniejszania całego haedera przy scrolowaniu w dół, jak to zrobić?
Support Team posted this 26 September 2017
Your Header should have the Sticky extension enabled. In the extension options you can set some fixed height value that will be lower than the initial header height. Then the height should be reduced when scrolled.
Hi, Your Header should have the Sticky extension enabled. In the extension options you can set some fixed height value that will be lower than the initial header height. Then the height should be reduced when scrolled. Sincerely, Hella
stryjek-www
stryjek-www posted this 26 September 2017
Witam , mam ustawiony nagłówek jako STICKY. Nie wiem co dalej mam zrobić? Jak zmienić rozmiar przed scrollem i po scrollowaniu strony?
Support Team posted this 27 September 2017
Unfortunately there are no direct options to change the style of the Header or its elements on scroll.
But as mentioned in the previous reply you can set the height to the affix container which wraps the Header on scroll. The Sticky extension has additional popup options when enabled.
The height can be specified under the Shape Options.
As alternative you can try manual solution which requires some css skills:
http://answers.themler.io/articles/96208/change-header-height-on-scroll
Hi, Unfortunately there are no direct options to change the style of the Header or its elements on scroll. But as mentioned in the previous reply you can set the height to the affix container which wraps the Header on scroll. The Sticky extension has additional popup options when enabled. !sticky-options.png! The height can be specified under the *Shape Options*. As alternative you can try manual solution which requires some css skills: http://answers.themler.io/articles/96208/change-header-height-on-scroll Thank you, Olivia
