Strange sencond menu behavior, changes position and alignment.
aureliop
aureliop posted this 29 September 2017
Hi.
Would you take a look at http://ssur.ypunto.com.mx/real-cayetana/giralda/. As you can see I have two menues: Main menu and another menu that shows only in certain pages.
Question 1. I put a big space in order to keep the second menu before, in order to make it visible when I scroll up the page, it is not hidden under the header. But when you reload the page or scroll all the page you see this space that is too much big. Is ther another way to do it?
Question 2
When I scroll down the page, some how the second menu changes position, it goes down almost to the middle of tha page and moves from right to left.
I would like to show you some screenshots, but I hope I explained it clear
Thanks.
aurelio Pérez
Hi. Would you take a look at http://ssur.ypunto.com.mx/real-cayetana/giralda/. As you can see I have two menues: Main menu and another menu that shows only in certain pages. Question 1. I put a big space in order to keep the second menu before, in order to make it visible when I scroll up the page, it is not hidden under the header. But when you reload the page or scroll all the page you see this space that is too much big. Is ther another way to do it? Question 2 When I scroll down the page, some how the second menu changes position, it goes down almost to the middle of tha page and moves from right to left. I would like to show you some screenshots, but I hope I explained it clear Thanks. aurelio Pérez
Support Team posted this 29 September 2017
HI,
I see the only issue when I scroll down, reload the page and the second menu becomes like 50% width and is floating to the left. that should be caused by the fact that the Sticky extension is applied to the menu and to some other container that includes this menu. When two sticky extensions are applied, they are conflicting in such a way.
I do not see the other issues, so maybe you could attach some screen shots.
HI, I see the only issue when I scroll down, reload the page and the second menu becomes like 50% width and is floating to the left. that should be caused by the fact that the Sticky extension is applied to the menu and to some other container that includes this menu. When two sticky extensions are applied, they are conflicting in such a way. I do not see the other issues, so maybe you could attach some screen shots. Sincerely, Hella
aureliop
Hi Hella.
Thank you for your fast answer.
Here are the screenshots:
I hope it is clear now.
thanks
Aurelio
Hi Hella. Thank you for your fast answer. Here are the screenshots: !ssur.ypunto-2.jpg! !ssur.ypunto-1.jpg! !ssur.ypunto-4.jpg! !ssur.ypunto-3.jpg! I hope it is clear now. thanks Aurelio
Support Team posted this 02 October 2017
If I understand correctly, then you need to remove that padding and then in the sticky extension options for that second menu set the top offset to 90px.
Hi, If I understand correctly, then you need to remove that padding and then in the sticky extension options for that second menu set the top offset to 90px. Sincerely, Hella
aureliop
aureliop posted this 09 October 2017
Thank you very much Hella..
I have another question: Would you tell me how to setup the space before the anchor text?
Please take a look at:
http://ssur.ypunto.com.mx/real-cayetana/real-cayetana-triana/
Inside the green box is the <h1 id></h1>.
The light blue box is to leave a blank space before the text “Características”. if you select “Fotografías” or any other text in the blue menu and then select “Caracteristicas” again, this section is in the same place as the other sections.
I don’t want this big space when I load the page.
In this link I remove that big space:
http://ssur.ypunto.com.mx/parques-quinceo/parque-quinceo-turquesa/
If you click “Fotografías” you can see the anchored title, and then click “Características” back the title is under the header.
thank you in advance
Aurelio
Thank you very much Hella.. I have another question: Would you tell me how to setup the space before the anchor text? Please take a look at: http://ssur.ypunto.com.mx/real-cayetana/real-cayetana-triana/ Inside the green box is the &lt;h1 id&gt;&lt;/h1&gt;. The light blue box is to leave a blank space before the text “Características”. if you select “Fotografías” or any other text in the blue menu and then select “Caracteristicas” again, this section is in the same place as the other sections. I don’t want this big space when I load the page. In this link I remove that big space: http://ssur.ypunto.com.mx/parques-quinceo/parque-quinceo-turquesa/ If you click “Fotografías” you can see the anchored title, and then click “Características” back the title is under the header. thank you in advance Aurelio
Support Team posted this 09 October 2017
Unfortunately that is how the anchors work. You need to add a space in order to make the content visible below the fixed header. Unfortunately there is nothing else you can do i the application.
Hi, Unfortunately that is how the anchors work. You need to add a space in order to make the content visible below the fixed header. Unfortunately there is nothing else you can do i the application. Sincerely, Hella
