Specific post in a container
blixem1978
blixem1978 posted this 3 weeks ago
Im working on a website for my wife in Wordpress.
I have a onepage design. I want to place a SPECIFIC posts inside a container (or whatever).
Is that possible? and how?
The website: www.joannekemarchal.nl
So right to my wife's picture there is some text. I want that text linked from a specific post.
So when is change the post i change the text on the frontpage.
Can somebody help me please?
Hello, Im working on a website for my wife in Wordpress. I have a onepage design. I want to place a SPECIFIC posts inside a container (or whatever). Is that possible? and how? The website: www.joannekemarchal.nl So right to my wife's picture there is some text. I want that text linked from a specific post. So when is change the post i change the text on the frontpage. Can somebody help me please? www.joannekemarchal.nl
Themler has special functionality to output CMS content - Posts control. It outputs the content provided by WordPress. For example, if you specified static page as WordPress front page under the WP Settings >> Reading the content of exactly this page will be displayed in the Posts control. Please make sure that CMS Content is enabled under the Design tab.
Hi, Themler has special functionality to output CMS content - Posts control. It outputs the content provided by WordPress. For example, if you specified static page as WordPress front page under the WP Settings >> Reading the content of exactly this page will be displayed in the Posts control. Please make sure that CMS Content is enabled under the Design tab. Thank you, Olivia
blixem1978
blixem1978 posted this 2 weeks ago
Thank you for this answer but this not an answer to my question?
I know that i can link a PAGE but i want to place a SPECIFIC post inside a container or a column. Then i want another SPECIFIC post in another container or a column.
So i just want to link the text from individual posts inside an ONE PAGE DESIGN.
Perhaps i can put different pages inside an ONE PAGE DESIGN but i cant find out how to do it.
So for instance i want on the left a picture and on the right the text from a SPECIFIC post
then below that
i want another row with on the left a picture and on the right the text from a SPECIFIC post
Best regards, Marc.
Thank you for this answer but this not an answer to my question? I know that i can link a PAGE but i want to place a SPECIFIC post inside a container or a column. Then i want another SPECIFIC post in another container or a column. So i just want to link the text from individual posts inside an ONE PAGE DESIGN. Perhaps i can put different pages inside an ONE PAGE DESIGN but i cant find out how to do it. So for instance i want on the left a picture and on the right the text from a SPECIFIC post then below that i want another row with on the left a picture and on the right the text from a SPECIFIC post Best regards, Marc.
This is quite different task. Please note that Themler creates themes only. The content is controlled and outputted by WP. It means that Themler theme with show exactly the same content on the WP page as any other theme.
In your case you can try using custom php code to output specific post by ID. The custom php code can be added into the CMS Code control (Insert tab >> More). The code can be found on the WP forums. There is nothing specific to Themler themes.
Unfortunately Themler itself does not provide fucn option because it is simply theme generator tool.
Hi, This is quite different task. Please note that Themler creates themes only. The content is controlled and outputted by WP. It means that Themler theme with show exactly the same content on the WP page as any other theme. In your case you can try using custom php code to output specific post by ID. The custom php code can be added into the CMS Code control (Insert tab >> More). The code can be found on the WP forums. There is nothing specific to Themler themes. Unfortunately Themler itself does not provide fucn option because it is simply theme generator tool. Thank you, Olivia
blixem1978
This is the CMS code:
Change the post ID and it works.
<?php $post_id $queried_post $content?>post_content;
$content = apply_filters('the_content', $content);
$content = str_replace(']]>', ']]>', $content);
echo $content;
This is the CMS code: Change the post ID and it works. &lt;?php $post_id $queried_post $content?&gt;post_content; $content = apply_filters('the_content', $content); $content = str_replace(']]>', ']]&gt;', $content); echo $content; ?>
We glad that you fount the solution. Please let us know if you need our further assistance here.
Hi, We glad that you fount the solution. Please let us know if you need our further assistance here. Thank you, Olivia
