display posts shortcode compatibility
moordigital
moordigital posted this 10 October 2017
Just wanted to check if you know of any compatibility issues when using the Display Posts Shortcode plugin (https://en.support.wordpress.com/display-posts-shortcode/) alongside Themler?
I have set up the Display Posts Shortcode and it is not responding to the posts_per_page parameter. I have no issues when setting up in the same way on another site I set up before using Themler.
Look forward to hearing. Many thanks in advance.
Angus
Hi, Just wanted to check if you know of any compatibility issues when using the Display Posts Shortcode plugin (https://en.support.wordpress.com/display-posts-shortcode/) alongside Themler? I have set up the Display Posts Shortcode and it is not responding to the posts_per_page parameter. I have no issues when setting up in the same way on another site I set up before using Themler. Look forward to hearing. Many thanks in advance. Angus
Support Team posted this 11 October 2017
Does the issue happen with the default WP theme on the same website?
I've tested this plugin on my side and it works ok with Themler theme.
Hi, Does the issue happen with the default WP theme on the same website? I've tested this plugin on my side and it works ok with Themler theme. Thank you, Olivia
moordigital
Is Solution
moordigital posted this 12 October 2017
Hi Olivia,
Thanks for getting back to me.
I just set up a local site to test and worked fine. I checked all plugins were the same on live & local sites to be sure no conflicts.
I went back to live site to test and without doing anything it now seems to be working! I'm pretty sure I had cleared the cache before trying earlier but maybe that was it?
Either way, all good now!
Many thanks.
Angus
Hi Olivia, Thanks for getting back to me. I just set up a local site to test and worked fine. I checked all plugins were the same on live & local sites to be sure no conflicts. I went back to live site to test and without doing anything it now seems to be working! I'm pretty sure I had cleared the cache before trying earlier but maybe that was it? Either way, all good now! Many thanks. Angus
Support Team posted this 12 October 2017
We glad that everything is ok now.
It is difficult to say what caused the issue on the live site. The caching issue is possible.
Hi, We glad that everything is ok now. It is difficult to say what caused the issue on the live site. The caching issue is possible. Thank you, Olivia
