Big Bug with visual composer urgent
bob52
bob52 posted this 12 October 2017
Hi there i got a mayor bug with visual composer.
i have my post pages on wide defined in the tab content and sidebars.
This gives me the option to make on the posts some rows stretched and others boxed.
The thing is only that all the posts get the [html] [/html] rows on the start and end of the pages.
That shouldn't be a problem as long when after editing the post there shouldn't appear [/vc_column_text][/vc_column][/vc_row] on the front screen
I tried to hide the [html] rows in the backend but then the content all together disappear. By deleting the [html] rows al the rows go to fluid.
I'm desperate.
The thing is that on the home template it seems just fine! So it just happens on posts!
I need to publish the site on monday so any help would be great!!!
Hi there i got a mayor bug with visual composer. i have my post pages on **wide** defined in the tab content and sidebars. This gives me the option to make on the posts some rows stretched and others boxed. The thing is only that all the posts get the [html] [/html] rows on the start and end of the pages. That shouldn't be a problem as long when after editing the post there shouldn't appear [/vc_column_text][/vc_column][/vc_row] on the front screen I tried to hide the [html] rows in the backend but then the content all together disappear. By deleting the [html] rows al the rows go to **fluid.** I'm desperate. The thing is that on the home template it seems just fine! So it just happens on posts! I need to publish the site on monday so any help would be great!!!
11 Comments
bob52
Do you have any clue??
Linkebel
Linkebel posted this 12 October 2017
A link ?
A link ?
bob52
http://www.apropic.com/line/
I can give you the login, but it has to be private
http://www.apropic.com/line/ I can give you the login, but it has to be private
Linkebel
Linkebel posted this 13 October 2017
I do not see your problem, I do not see any shortcode in any page
bob52
bob52 posted this 13 October 2017
Hi Linkebel, i did make a private topic yesterday with a sample included.
http://www.apropic.com/line/home/apropic-bio/ is the link for example.
That is a blog post. in the private topic you find the additional login for the wordpress.
Thank you!
Hi Linkebel, i did make a private topic yesterday with a sample included. http://www.apropic.com/line/home/apropic-bio/ is the link for example. That is a blog post. in the private topic you find the additional login for the wordpress. Thank you!
bob52
All the pages you see on the http://www.apropic.com/line/ are pages. as a workaround...
Linkebel
actually it's weird
To solve this bug the Themeler team must intervene.
As a temporary solution you can hide the shortcode with css, in the page http://www.apropic.com/line/home/apropic-bio/ just add this code css
.vc_custom_1507718494306 {margin-top: -20px !important;}
Does it help you?
actually it's weird To solve this bug the Themeler team must intervene. As a temporary solution you can hide the shortcode with css, in the page http://www.apropic.com/line/home/apropic-bio/ just add this code css .vc_custom_1507718494306 {margin-top: -20px !important;} Does it help you?
bob52
actually it's weird
Does it help you?
Hmmm... then i need to give the second row extra margins... Does this css code work on every post page i make? or does the bug-code per post appear in a new cell with a new id (variations on 1507718494306)
> actually it's weird > > To solve this bug the Themeler team must intervene. > > As a temporary solution you can hide the shortcode with css, in the page http://www.apropic.com/line/home/apropic-bio/ just add this code css > > .vc_custom_1507718494306 {margin-top: -20px !important;} > > Does it help you? Hmmm... then i need to give the second row extra margins... Does this css code work on every post page i make? or does the bug-code per post appear in a new cell with a new id (variations on 1507718494306)
bob52
yes in visual composer when i give the row that includes [html] a margin of -20px it hides [/vc_column_text][/vc_column][/vc_row] in the frontpage. .vc_custom_1507718494306 {margin-top: -20px !important;} doesn't seem to work.
Still its a strange bug. And Visual composer is wide used so please consider this bug as urgent.
yes in visual composer when i give the row that includes [html] a margin of -20px it hides [/vc_column_text][/vc_column][/vc_row] in the frontpage. .vc_custom_1507718494306 {margin-top: -20px !important;} doesn't seem to work. Still its a strange bug. And Visual composer is wide used so please consider this bug as urgent.
Linkebel
I think you'll have to put that css code in every post page you create.
The number 1507718494306 each for each post page in my opinion.
I hope the Themler team will be able to help you as fast as possible but communication is unfortunately not their strong point which has made me leave the Themler adventure.
I think you'll have to put that css code in every post page you create. The number 1507718494306 each for each post page in my opinion. I hope the Themler team will be able to help you as fast as possible but communication is unfortunately not their strong point which has made me leave the Themler adventure.
Linkebel
If necessary give me every link where you need a margin-top -20px and I give you the css code
