Drupal 8 error when edit theme
mostafax222
mostafax222 posted this 22 October 2017
OS: Linux mostafa-K52F 4.10.0-37-generic #41-Ubuntu SMP Fri Oct 6 20:20:37 UTC 2017 x86_64 E_NOTICE: A non well formed numeric value encountered /var/www/html/themler/modules/themler/src/helpers/pclzip/pclzip.lib.php 1845 Callstack: -> PclZip::privOptionDefaultThreshold(array(2) { ... }) -> PclZip::extract(77001, '/var/www/h...') -> Chunk::unzip('PK ...') -> Chunk::complete() -> export('untitled', array(7) { ... }) -> themler_export() -> themler_process_request('process_re...') -> Drupal\themler\Controller\ThemlerController::process_request('process_re...') -> call_user_func_array(Drupal\themler\Controller\ThemlerController->process_request, array(1) { ... }) -> Drupal\Core\EventSubscriber\EarlyRenderingControllerWrapperSubscriber::Drupal\Core\EventSubscriber{closure}() -> Drupal\Core\Render\Renderer::executeInRenderContext(Drupal\Core\Render\RenderContext(...) { ... }, Closure(...) { ... }) -> Drupal\Core\EventSubscriber\EarlyRenderingControllerWrapperSubscriber::wrapControllerExecutionInRenderContext(Drupal\themler\Controller\ThemlerController->process_request, array(1) { ... }) -> Drupal\Core\EventSubscriber\EarlyRenderingControllerWrapperSubscriber::Drupal\Core\EventSubscriber{closure}() -> call_user_func_array(Closure(...) { ... }, array(0) { ... }) -> Symfony\Component\HttpKernel\HttpKernel::handleRaw(Symfony\Component\HttpFoundation\Request(...) { ... }, 1) -> Symfony\Component\HttpKernel\HttpKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\Session::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\KernelPreHandle::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\page_cache\StackMiddleware\PageCache::pass(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\page_cache\StackMiddleware\PageCache::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\ReverseProxyMiddleware::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\NegotiationMiddleware::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Stack\StackedHttpKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\DrupalKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... })
OS: Linux mostafa-K52F 4.10.0-37-generic #41-Ubuntu SMP Fri Oct 6 20:20:37 UTC 2017 x86_64 E_NOTICE: A non well formed numeric value encountered /var/www/html/themler/modules/themler/src/helpers/pclzip/pclzip.lib.php 1845 Callstack: -> PclZip::privOptionDefaultThreshold(array(2) { ... }) -> PclZip::extract(77001, '/var/www/h...') -> Chunk::unzip('PK ...') -> Chunk::complete() -> export('untitled', array(7) { ... }) -> themler_export() -> themler_process_request('process_re...') -> Drupal\themler\Controller\ThemlerController::process_request('process_re...') -> call_user_func_array(Drupal\themler\Controller\ThemlerController->process_request, array(1) { ... }) -> Drupal\Core\EventSubscriber\EarlyRenderingControllerWrapperSubscriber::Drupal\Core\EventSubscriber\{closure}() -> Drupal\Core\Render\Renderer::executeInRenderContext(Drupal\Core\Render\RenderContext(...) { ... }, Closure(...) { ... }) -> Drupal\Core\EventSubscriber\EarlyRenderingControllerWrapperSubscriber::wrapControllerExecutionInRenderContext(Drupal\themler\Controller\ThemlerController->process_request, array(1) { ... }) -> Drupal\Core\EventSubscriber\EarlyRenderingControllerWrapperSubscriber::Drupal\Core\EventSubscriber\{closure}() -> call_user_func_array(Closure(...) { ... }, array(0) { ... }) -> Symfony\Component\HttpKernel\HttpKernel::handleRaw(Symfony\Component\HttpFoundation\Request(...) { ... }, 1) -> Symfony\Component\HttpKernel\HttpKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\Session::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\KernelPreHandle::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\page_cache\StackMiddleware\PageCache::pass(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\page_cache\StackMiddleware\PageCache::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\ReverseProxyMiddleware::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\NegotiationMiddleware::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Stack\StackedHttpKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\DrupalKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... })
mostafax222
screen shot
screen shot
Support Team posted this 23 October 2017
Could you please try installing this theme. Does the issue continue?
I suggest that you remove the previous theme and module and clear Drupal cache.
Hi, Could you please try installing this theme. Does the issue continue? I suggest that you remove the previous theme and module and clear Drupal cache. Thank you, Olivia
mostafax222
mostafax222 posted this 26 October 2017
error
error
mostafax222
error
error
Support Team posted this 12 December 2017
We are sorry for such delay. We have just found the topic unanswered in our system. Is the issue still actual?
Hello, We are sorry for such delay. We have just found the topic unanswered in our system. Is the issue still actual? Sincerely, Nettie, BillionDigital Team
