Populating Top Sidebar with Woocommerce product categories
BeatM
BeatM posted this 26 October 2017
how do I populate the top sidebar with woocommerce product categories. Which widget area belongs to it ?
and how to setup pagination on woocommerce product page and product detail ?
Thanks and best regards
Beat
Hi, how do I populate the top sidebar with woocommerce product categories. Which widget area belongs to it ? and how to setup pagination on woocommerce product page and product detail ? Thanks and best regards Beat
Support Team posted this 27 October 2017
Top Sidebars is just an area to share control. If you want to display WP widgets inside this sidebar you need to add WP Widget Area control (Insert tab) into this sidebar and then put WP widget into this widget area under the WP Appearance >> Widgets. You can use any WP widgets in WP widget areas.
What exactly you mean by "pagination on product details"?
Hi, Top Sidebars is just an area to share control. If you want to display WP widgets inside this sidebar you need to add *WP Widget Area* control (Insert tab) into this sidebar and then put WP widget into this widget area under the WP Appearance >> Widgets. You can use any WP widgets in WP widget areas. What exactly you mean by "pagination on product details"? Thank you, Olivia
