Version themler download
libertad3613
libertad3613 posted this 26 October 2017
the themler version for download is 3.19, which happens when the subscription is fulfilled and you want to continue working without updating, if for some circumstance a new installation is made on the desktop, you still have the option to upgrade to a version higher than 3.19?
Support Team posted this 26 October 2017
There is a difference between version of Themler desktop application, like Themler.1.0.319.fe25b, and Themler version, like v.418. When you install Themler desktop, Themler themes that are created by default, may have the latest or not the latest version. You may wish also updating them, if any updates are available. If you subscription has expired, and you have installed Themler desktop after this, Themler version can be newer than one allowed for your subscription. In this case Themler will work in trial mode (without saving and export possible). There is no source with older Themler versions available. For this purpose you may export and backup your themes in the latest version allowed for your license and keep them somewhere, or keep older Themler desktop .exe file to be installed later.
Hello, There is a difference between version of Themler desktop application, like Themler.1.0.319.fe25b, and Themler version, like v.418. When you install Themler desktop, Themler themes that are created by default, may have the latest or not the latest version. You may wish also updating them, if any updates are available. If you subscription has expired, and you have installed Themler desktop after this, Themler version can be newer than one allowed for your subscription. In this case Themler will work in trial mode (without saving and export possible). There is no source with older Themler versions available. For this purpose you may export and backup your themes in the latest version allowed for your license and keep them somewhere, or keep older Themler desktop .exe file to be installed later. Sincerely, Nettie, BillionDigital Team
