add-to-cart-button within the form (product variations)
engels
engels posted this 06 November 2017
Hi themler team,
in order to get a WP-plugin (define and calculate product options instead of product variants) work proper I need the add-to-cart-button to be placed WITHIN the form.cart on the product detail template. But in themler there is no possibility to add a control in the control product variations that would achieve that, isn't it?
Is there a workaround?
Nearly every wp theme has these button placed within form.cart, but not themler. Grrr...
Thanks in advance.
Koepi
Hi themler team, in order to get a WP-plugin (define and calculate product options instead of product variants) work proper I need the add-to-cart-button to be placed WITHIN the form.cart on the product detail template. But in themler there is no possibility to add a control in the control product variations that would achieve that, isn't it? Is there a workaround? Nearly every wp theme has these button placed within form.cart, but not themler. Grrr... Thanks in advance. Koepi !screenshot-01.jpg! !screenshot-02.jpg!
Support Team posted this 08 November 2017
Unfortunately the "Add to Cart" button in Themler themes is a separate control which can be moved inside Product control separately from other controls. Unfortunately there is no way to move it inside Product Variations control in Themler.
As a workaround you can try to edit theme files manually and move the button but we cannot guarantee that the button will work in this case.
Hi, Unfortunately the "Add to Cart" button in Themler themes is a separate control which can be moved inside Product control separately from other controls. Unfortunately there is no way to move it inside Product Variations control in Themler. As a workaround you can try to edit theme files manually and move the button but we cannot guarantee that the button will work in this case. Thank you, Olivia
