Joomla Template Themler for Windows 404 - Article not found
butterfly_webdesign
butterfly_webdesign posted this 08 November 2017
i try to create a new theme for joomla on my Themler for Windows. Allways when i try to create a new joomla Template it shows 404 - Article not found
Whats wrong?
Hello, i try to create a new theme for joomla on my Themler for Windows. Allways when i try to create a new joomla Template it shows 404 - Article not found Whats wrong?
11 Comments
Support Team posted this 08 November 2017
Could you please try to rename the following folder into joomla-old and try to run Themler once again:
C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla
Hi, Could you please try to rename the following folder into **joomla-old** and try to run Themler once again: C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla Sincerely, Nettie, BillionDigital Team
butterfly_webdesign
OK Thank you this fixed the problem :)
You are welcome!
You are welcome! Sincerely, Nettie, BillionDigital Team
darin
darin posted this 15 January 2018
This answer causes me to loose access to my other templates. Do you have a better solution?
darin
Also, when I switch it back, I now get the 404 error on all my other templates.
> This answer causes me to loose access to my other templates. Do you have a better solution? Also, when I switch it back, I now get the 404 error on all my other templates.
Support Team posted this 16 January 2018
You won't loose your created themes, they will stay in the joomla-old folder. You will be able to zip-compress each of them and import them as Zip later, when tthe issue is fixed.
Hello, You won't loose your created themes, they will stay in the joomla-old folder. You will be able to zip-compress each of them and import them as Zip later, when tthe issue is fixed. Sincerely, Nettie, BillionDigital Team
darin
darin posted this 16 January 2018
The problem that was presenting this issue for me was that the Home menu (default Joomla Menu) was pointing to a missing article. This happened to me twice now, and I am unsure why Themler is doing this. The fix is to reassign an article to the menu item.
> > This answer causes me to loose access to my other templates. Do you have a better solution? > > Also, when I switch it back, I now get the 404 error on all my other templates. The problem that was presenting this issue for me was that the Home menu (default Joomla Menu) was pointing to a missing article. This happened to me twice now, and I am unsure why Themler is doing this. The fix is to reassign an article to the menu item.
A similar issue has been fixed recently. Please make sure to update Themler to the latest version.
Hello, A similar issue has been fixed recently. Please make sure to update Themler to the latest version. Sincerely, Nettie, BillionDigital Team
Giuma
Giuma posted this 22 April 2018
SOLUTION
in joomla admin panel
go to menu
set "home" default page
SOLUTION in joomla admin panel go to menu set "home" default page
schmid.dominik
schmid.dominik posted this 04 January 2019
Hi there
Had the same issue here. That fixed it. Tanks
Sincerly
Domi
> Hi, > > Could you please try to rename the following folder into **joomla-old** and try to run Themler once again: > > C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla > > Sincerely, > Nettie, > BillionDigital Team Hi there Had the same issue here. That fixed it. Tanks Sincerly Domi
Support Team posted this 04 January 2019
Domi, thanks for letting us know. Please feel free to contact us in any other case.
Domi, thanks for letting us know. Please feel free to contact us in any other case. Sincerely, Nettie
