The CSS Class @keyframes getting changed to @@keyframes after exporting to html. Why ???
Webnoesys IT Solutions LLP
Webnoesys IT Solutions LLP posted this 08 November 2017
Dear Sir,
The @keyframes class after exporting its getting changed to @@keyframes leading to not working of my classes. I am doing manually edit by removing additioanl @ and then saving in order to work. Why ???
Sample given below,
@keyframes scrollin
0% {left:800px;}
100% {left:-800px;}
Need your support for the same, how to overcome this issue. ???
Kindly find the screenshot attached.
Suffian Ahmed
Dear Sir, The @keyframes class after exporting its getting changed to @@keyframes leading to not working of my classes. I am doing manually edit by removing additioanl @ and then saving in order to work. Why ??? Sample given below, @keyframes scrollin { 0% {left:800px;} 100% {left:-800px;} } Need your support for the same, how to overcome this issue. ??? Kindly find the screenshot attached. Regards Suffian Ahmed
8 Comments
This is also one more issue we are getting after exporting. I belive this issues/bugs appering after latest updates only.
<script src="//load.sumome.com/" data-sumo-site-id="78b552e9fb234177938ead9d529cf1536a29dc31d2ee106f0134bf9c8d241b49" async="async"></script>
Why src="/load.sumome.com/" slash appending on this URL src ???
Need your fixes on this at higher priority, lots of third party css & scripts are not functioning please...
Suffian Ahmed
This is also one more issue we are getting after exporting. I belive this issues/bugs appering after latest updates only. <script src="//load.sumome.com/" data-sumo-site-id="78b552e9fb234177938ead9d529cf1536a29dc31d2ee106f0134bf9c8d241b49" async="async"></script> Why `src="/load.sumome.com/"` slash appending on this URL src ??? Need your fixes on this at higher priority, lots of third party css & scripts are not functioning please... Regards Suffian Ahmed
Again more examples, kindly find the screenshot too for your understanidng
<script id="dsq-count-scr" src="//sochsolarsystems.disqus.com/count.js" async></script>
// is appending in the above script //sochsolarsystems.disqus.com/count.js why // appended ????
Suffian Ahmed
Again more examples, kindly find the screenshot too for your understanidng <script id="dsq-count-scr" src="//sochsolarsystems.disqus.com/count.js" async></script> // is appending in the above script `//sochsolarsystems.disqus.com/count.js` why // appended ???? Regards Suffian Ahmed
Webnoesys IT Solutions LLP posted this 16 November 2017
Any updates on my issue...?????
Suffian Ahmed
Any updates on my issue...????? Regards Suffian Ahmed
Webnoesys IT Solutions LLP posted this 11 December 2017
Any updates on this point..
Suffian Ahmed
Any updates on this point.. Regards Suffian Ahmed
Support Team posted this 11 December 2017
Exactly where you add this code? I've tested it on my side and everything is ok.
Does the issue happen is you SAVE the theme, not PUBLISH?
Did you try to specify complete path like: http://load.sumome.com? The full path should work better.
Hi, > The @keyframes class after exporting its getting changed to @@keyframes Exactly where you add this code? I've tested it on my side and everything is ok. Does the issue happen is you SAVE the theme, not PUBLISH? > Why src="/load.sumome.com/" slash appending on this URL src ??? Did you try to specify complete path like: `http://load.sumome.com`? The full path should work better. Thank you, Olivia
Webnoesys IT Solutions LLP posted this 12 December 2017
But, why i am facing this issue. I will share my project file for your reference.
And, yes i have specify complete path but still http:// removed and just appended with // Why?
Find the screenshot for the same.
Suffian Ahmed
But, why i am facing this issue. I will share my project file for your reference. And, yes i have specify complete path but still http:// removed and just appended with // Why? Find the screenshot for the same. Regards Suffian Ahmed
Dear Olivia,
Source File where we have used @@keyframes and output missing single @.
Download the .zip fiel source and review the same,
We have attached screenshot of the script too. We are using the CSS @@Keyframes under EDIT HTML HTML Control inside <style> tabe not under EDIT CSS section.
The @@keyframe us under the style tag it shoult not file i believe.
Suffian Ahmed
Dear Olivia, Source File where we have used @@keyframes and output missing single @. Download the .zip fiel source and review the same, We have attached screenshot of the script too. We are using the CSS @@Keyframes under EDIT HTML HTML Control inside <style> tabe not under EDIT CSS section. The @@keyframe us under the style tag it shoult not file i believe. Regards Suffian Ahmed
Support Team posted this 14 December 2017
Here is what I tried:
  1. downloaded the attached theme and opened it in Themler
  2. added new HTML control and copied css from the existing html control
  3. removed second @
  4. saved changes and refreshed the page. The rule looks ok.
  5. I also tried to edit and save existing HTML control with the same result. Are you sure that original css contains this rule with one @?
Hi, Here is what I tried: 1. downloaded the attached theme and opened it in Themler 2. added new HTML control and copied css from the existing html control 3. removed second `@` 4. saved changes and refreshed the page. The rule looks ok. 5. I also tried to edit and save existing HTML control with the same result. Are you sure that original css contains this rule with one `@`? Thank you, Olivia
