Horizontal menu submenu keeps loosing settings
len
len posted this 09 November 2017
I change the settings for the horizontal menu > submenu border, and active item background, looks fine then save
I am trying to get the "show submenu arrow" to work, but no icon set anywhere seems to appear. What does happen is the previous changes to the menus are then lost.
Is the submenu arrow function broken? I thought it was the Horizontal Menu > Horizontal Menu > Item > Item > Icon to set? Is that the right place?
In Horizontal Menu settings panel, the "Item" section appears twice, at the top and at the bottom of the list, why is this please?
This is why I get frustrated with Themler! I have created many websites with it, but recently started with the Divi theme, but decided to do the next site with Themler. Yet again, it does just not work as it should.
Help appreciated, thanks.
I change the settings for the horizontal menu > submenu border, and active item background, looks fine then save I am trying to get the "show submenu arrow" to work, but no icon set anywhere seems to appear. What does happen is the previous changes to the menus are then lost. Is the submenu arrow function broken? I thought it was the Horizontal Menu > Horizontal Menu > Item > Item > Icon to set? Is that the right place? In Horizontal Menu settings panel, the "Item" section appears twice, at the top and at the bottom of the list, why is this please? This is why I get frustrated with Themler! I have created many websites with it, but recently started with the Divi theme, but decided to do the next site with Themler. Yet again, it does just not work as it should. Help appreciated, thanks.
Support Team posted this 10 November 2017
The Menu item icon can be configured under the Hmenu >> Menu Item >> Icon. When the "show submenu arrow" option is enabled the icon will be displayed if the item has subitems only.
It is better to navigate menu options from the Ribbon. Horizontal menu has different types and responsive settings. Therefore there a few items as grouped controls and it can confuse. But if you work from ribbon you will understand what item and where it is located.
Hi, The Menu item icon can be configured under the Hmenu >> Menu Item >> Icon. When the "show submenu arrow" option is enabled the icon will be displayed if the item has subitems only. It is better to navigate menu options from the Ribbon. Horizontal menu has different types and responsive settings. Therefore there a few items as grouped controls and it can confuse. But if you work from ribbon you will understand what item and where it is located. Thank you, Olivia
