Horizontal menu jumping about
eleanor
eleanor posted this 14 November 2017
I have a horizontal menu contained inside the header that sticks when you scroll down the page.
At times, as you scroll, the menu jumps to the side of the page.
https://www.carpet.ywdw.co.uk
Do you have a solution to this one?
Hi I have a horizontal menu contained inside the header that sticks when you scroll down the page. At times, as you scroll, the menu jumps to the side of the page. !menu-jumping-001.JPG! https://www.carpet.ywdw.co.uk Do you have a solution to this one? Thank you
Support Team posted this 14 November 2017
Usually this issue happens when you enabled two or more Sticky extensions for controls inside the same container. Please check enabled extensions of the section with menu and all inner containers.
Hi, Usually this issue happens when you enabled two or more Sticky extensions for controls inside the same container. Please check enabled extensions of the section with menu and all inner containers. Thank you, Olivia
eleanor
Is Solution
eleanor posted this 15 November 2017
Spot on!
Thank you as always!
Kind regards
Spot on! Thank you as always! Kind regards
Support Team posted this 15 November 2017
You're welcome!
Hi, You're welcome! Thank you, Olivia
