Functions.php added code not working
rianne
rianne posted this 15 November 2017
I have the plugin client portal. I wanted my users to get an email when I update their private page, so I asked the developer of the plugin. I can add the following code to my functions.php:
//Send an email to the user when his private page was updated
function cpc_send_email_on_page_update($post_id) {
$author_id = get_post_field('post_author', $post_id);
$user = get_userdata($author_id);
$to = $user->user_email;
$site_name = get_bloginfo('name');
$subject = '['.$site_name.'] Private page updated !';
$message = 'Your private page was just updated !';
wp_mail($to, $subject, $message);
add_action( 'save_post_private-page', 'cpc_send_email_on_page_update' );
When I activate the twenty seventeen theme the extra code in the functions.php works fine. But when I activate the Themler theme I made, it does not work.
I added the code in the functions.php of both the Twenty Seventeen theme and my Themler theme.
Does anyone know what can be the problem?
Hello, I have the plugin client portal. I wanted my users to get an email when I update their private page, so I asked the developer of the plugin. I can add the following code to my functions.php: //Send an email to the user when his private page was updated function cpc_send_email_on_page_update($post_id) { $author_id = get_post_field('post_author', $post_id); $user = get_userdata($author_id); $to = $user->user_email; $site_name = get_bloginfo('name'); $subject = '['.$site_name.'] Private page updated !'; $message = 'Your private page was just updated !'; wp_mail($to, $subject, $message); } add_action( 'save_post_private-page', 'cpc_send_email_on_page_update' ); When I activate the twenty seventeen theme the extra code in the functions.php works fine. But when I activate the Themler theme I made, it does not work. I added the code in the functions.php of both the Twenty Seventeen theme and my Themler theme. Does anyone know what can be the problem?
Support Team posted this 15 November 2017
Did you try adding the code to the Themler Settings >> CMS Code?
This is the proper place to add custom php and usually everything work ok.
Hi, Did you try adding the code to the Themler Settings >> CMS Code? This is the proper place to add custom php and usually everything work ok. Thank you, Olivia
rianne
I did not try that, but I did just now.
I get an error saying it is unrecognised code.
I did not try that, but I did just now. I get an error saying it is unrecognised code.
I've tried to add it to the WP theme on my side and it does not return any error messages. Are you sure that you added it exactly into the CMS Code field?
Olviia
Hi, I've tried to add it to the WP theme on my side and it does not return any error messages. Are you sure that you added it exactly into the CMS Code field? Thank you, Olviia
rianne
Is Solution
Thnx Olivia, that was the problem, I accidentaly used the field for extra CSS in stead of CMS code.
I managed to get the code in and the code is also working.
Thnx Olivia, that was the problem, I accidentaly used the field for extra CSS in stead of CMS code. I managed to get the code in and the code is also working.
Support Team posted this 16 November 2017
Great!
Please let us know if you have any other questions/issues.
Hi, Great! Please let us know if you have any other questions/issues. Thank you, Olivia
