Menu crashes in browser and Themler
andrewatya
andrewatya posted this 22 November 2017
Sometimes my sticky header crashes and gets smaller when I edit theme, scroll, or sg. It also happens when I open menus on my site's frontend. I attached a printscreen to understand clearly that I meant.
Is it a software bug or a trouble in the template?
AndrĂ¡s
Hi, Sometimes my sticky header crashes and gets smaller when I edit theme, scroll, or sg. It also happens when I open menus on my site's frontend. I attached a printscreen to understand clearly that I meant. Is it a software bug or a trouble in the template? Thanks, András
Support Team posted this 23 November 2017
Usually it happens when control with "Sticky" extension contains one more control with "Sticky" extension. Please check all controls inside Header and disable all "Sticky" extensions, then save and enable "Sticky"for the Header control.
This should help.
Hi, Usually it happens when control with "Sticky" extension contains one more control with "Sticky" extension. Please check all controls inside Header and disable all "Sticky" extensions, then save and enable "Sticky"for the Header control. This should help. Thank you, Olivia
andrewatya
andrewatya posted this 23 November 2017
Hi olivia,
Thank you for youir great help! It seems to be working now, I will check it continuously...
Andras
Hi olivia, Thank you for youir great help! It seems to be working now, I will check it continuously... Regards, Andras
Support Team posted this 24 November 2017
You are welcome, please let us know if you have any further issues.
Hi, You are welcome, please let us know if you have any further issues. Sincerely, Hella
