I can't export joomla theme or publish it
themler131
themler131 posted this 24 November 2017
when I try to export joomla theme from themeler desktop version (windows 10) I get an error: "Fehler: Netzwerkfehler".
I also can not see any created themes on my profile page!
regards
Oliver
Hi, when I try to export joomla theme from themeler desktop version (windows 10) I get an error: "Fehler: Netzwerkfehler". I also can not see any created themes on my profile page! regards Oliver
Support Team posted this 24 November 2017
The themes created locally are available locally only. They will not be visible in your Profile on themler.io
Do you have internet connection on the computer you're working with Themler Desktop on?
Hi, The themes created locally are available locally only. They will not be visible in your Profile on themler.io Do you have internet connection on the computer you're working with Themler Desktop on? Thank you, Olivia
Jspriso
Jspriso posted this 25 January 2019
Is this isuue solved. I am running the same problem with Joomla.
The theme is ok localy, but I can't export it.
The message is: Echec - Problème avec le serveur.
Hello, Is this isuue solved. I am running the same problem with Joomla. The theme is ok localy, but I can't export it. The message is: **Echec - Problème avec le serveur.**
Support Team posted this 25 January 2019
Please try temporarily disabling antivirus, firewall and add-ons for the Chrome browser. Let us know if this helps.
Meanwhile you you try to copy the theme folder from C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla
Then zip-compress it and install in your Joomla on a server.
Hello, Please try temporarily disabling antivirus, firewall and add-ons for the Chrome browser. Let us know if this helps. Meanwhile you you try to copy the theme folder from C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla Then zip-compress it and install in your Joomla on a server. Sincerely, Nettie
