How I can remove the lightbox effect a template for wordpress ?
Carlos
Carlos posted this 27 November 2017
HI,
How I can remove the lightbox effect a template for wordpress ? when I click on every image it opens it as pop up.
HI, How I can remove the lightbox effect a template for wordpress ? when I click on every image it opens it as pop up. Thanks Regards
Support Team posted this 28 November 2017
Open the problem page in Themler, then go to the Outline in the left panel and find the Posts control (should be within the CMS Code control), click on it to open its options on the top ribbon and go to the Post Content drop-down, there you can switch off the Lightbox option.
Hi, Open the problem page in Themler, then go to the Outline in the left panel and find the Posts control (should be within the CMS Code control), click on it to open its options on the top ribbon and go to the Post Content drop-down, there you can switch off the Lightbox option. Sincerely, Hella
