Section with columns
rianne
rianne posted this 30 November 2017
I want to use a section with columns in it. So I can export the section and import it in other themplates.
But I have a problem with the spacing.
enter image description here
Hello, I want to use a section with columns in it. So I can export the section and import it in other themplates. But I have a problem with the spacing. ![enter image description here][1] ![enter image description here][2] [1]: https://dogmadesign.nl/themler/Themler%20-%20columns.png [2]: https://dogmadesign.nl/themler/Themler%20-%20columns%202.png
Support Team posted this 30 November 2017
HI,
Please attach the theme with the original section and also the theme where this section does not look correct. The themes should be exported with the content and editor included.
HI, Please attach the theme with the original section and also the theme where this section does not look correct. The themes should be exported with the content and editor included. Sincerely, Hella
rianne
Hello Hella,
Here are links to the two files:
https://dogmadesign.nl/themler/VT%20-right%20-%20SintCatharinadal%20incl%20themler%20en%20content.zip
https://dogmadesign.nl/themler/VT%20-wrong%20-%20SintCatharinadal%20incl%20themler%20en%20content.zip
In the right one the layout is right, but I cannot save this layout for future use, because it is not in a section.
In the wrong one I can save the layout for future use, but the layout is wrong.
Kind regards,
Rianne
Hello Hella, Here are links to the two files: https://dogmadesign.nl/themler/VT%20-right%20-%20SintCatharinadal%20incl%20themler%20en%20content.zip https://dogmadesign.nl/themler/VT%20-wrong%20-%20SintCatharinadal%20incl%20themler%20en%20content.zip In the right one the layout is right, but I cannot save this layout for future use, because it is not in a section. In the wrong one I can save the layout for future use, but the layout is wrong. Kind regards, Rianne
Support Team posted this 01 December 2017
I do not see the issue with the width in your theme. The problem with the search filed is there. It happens because the Section control has its own styles for the input field. To remove it go to the Section >> More Styles >> Input >> Style and set it to No style.
Hi, I do not see the issue with the width in your theme. The problem with the search filed is there. It happens because the Section control has its own styles for the input field. To remove it go to the Section >> More Styles >> Input >> Style and set it to No style. Sincerely, Hella
rianne
rianne posted this 03 December 2017
Yes, that worked!
Thank you very much.
For the problem with the width there was a similar kind of solution.
Yes, that worked! Thank you very much. For the problem with the width there was a similar kind of solution.
Support Team posted this 04 December 2017
