Displaying WordPress Menu Item Descriptions
copywriter
copywriter posted this 05 December 2017
Hello, can you get Themler to display a description in the menu? Thanks. Lucy
Support Team posted this 06 December 2017
I assume that it also won't appear with the default WP theme. To make it appear you may need to add some custom code in the theme. I believe that you can find some instructions over the internet.
Hi, I assume that it also won't appear with the default WP theme. To make it appear you may need to add some custom code in the theme. I believe that you can find some instructions over the internet. Sincerely, Hella
copywriter
copywriter posted this 06 December 2017
I tried this, but unfortunately did not work.
http://www.wpbeginner.com/wp-themes/how-to-add-menu-descriptions-in-your-wordpress-themes/
I tried this, but unfortunately did not work. http://www.wpbeginner.com/wp-themes/how-to-add-menu-descriptions-in-your-wordpress-themes/
Support Team posted this 12 December 2017
Looks like solution works with native wp menu object only.
Themler theme uses own menu which does not support menu item description by default.
Hi, Looks like solution works with native wp menu object only. Themler theme uses own menu which does not support menu item description by default. Thank you, Olivia
bsjelin
bsjelin posted this 06 July 2019
Is there any other ways to achieve "subtext" for a menu item? Similar to the attached image. I've been trying to figure this out without using ANOTHER 3rd party plugin.
enter image description here
Is there any other ways to achieve "subtext" for a menu item? Similar to the attached image. I've been trying to figure this out without using ANOTHER 3rd party plugin. ![enter image description here][1] [1]: http://forumattachments.themler.io/273/40273/Capture.PNG
