problem with submenu
webcompanysale
webcompanysale posted this 06 December 2017
hi
in front page:
when hover on button, the submenu dont open good, it under the slider.(1.jpg)
after scroling a litle its good.(2.jpg)
in pages:
when i hover on the menu button and try go to submenu it desapre.
thanks
hi in front page: when hover on button, the submenu dont open good, it under the slider.(1.jpg) after scroling a litle its good.(2.jpg) in pages: when i hover on the menu button and try go to submenu it desapre. thanks
Support Team posted this 06 December 2017
The images are not attached to the message. But I assume that you can try to do the following. Your menu is located inside the Header? And the slider is outside the header? Then open the Header settings and set the position option to relative and the z-index property to 1000.
If that does not help, provide an access to the site back end.
Hi, The images are not attached to the message. But I assume that you can try to do the following. Your menu is located inside the Header? And the slider is outside the header? Then open the Header settings and set the position option to `relative` and the z-index property to `1000`. If that does not help, provide an access to the site back end. Sincerely, Hella
webcompanysale
I ADD THE PIC
I ADD THE PIC
webcompanysale
ITS WORK
THWNKS
ITS WORK THWNKS
