Problem with lay out on Iphone and Ipad
arawolf
arawolf posted this 13 December 2017
On the site zakenkantoordemaeyer.be aren't the Phone numbers in the header visible on Iphone or Ipad, on other divices the numbers are visible in a white font. In the footer i have the same problem, but the numbers are visible on i-devices in blue instead of white.
Support Team posted this 13 December 2017
i-devices render the phone number like a link as they allow you to dial it from the site page. So they pick up the default link color from the theme. And that is a dark blue. I suggest you to edit the link color in the settings on that control.
Hi, i-devices render the phone number like a link as they allow you to dial it from the site page. So they pick up the default link color from the theme. And that is a dark blue. I suggest you to edit the link color in the settings on that control. Sincerely, Hella
arawolf
Thanxs these seems to solved the problem but now the footer go's nana, The table with the
opening hours isn't correctly lay out.
Thanxs these seems to solved the problem but now the footer go's nana, The table with the opening hours isn't correctly lay out.
The table with the
The two middle containers have negative margin (-9px) which causes this overlapping. In case of Wednesday this is row and in case of Thursday this is Container control.
Hi, > The table with the opening hours isn't correctly lay out. The two middle containers have negative margin (-9px) which causes this overlapping. In case of Wednesday this is row and in case of Thursday this is Container control. Thank you, Olivia
