Where to set up default THEME styles ??
JPa
JPa posted this 13 December 2017
Hi friends .. .
- font colors, sizes, ... H1-H6, bullets, ...
from these it will be inherited to others ...
\JPa
Hi friends .. . Where to set up default THEME styles ?? - font colors, sizes, ... H1-H6, bullets, ... from these it will be inherited to others ... Thanks \JPa
Support Team posted this 13 December 2017
Default styles can be set in the Design tab. Many elements are accessible on the ribbon, and you can open more by clicking More Styles on the very right of the ribbon.
Hello, Default styles can be set in the Design tab. Many elements are accessible on the ribbon, and you can open more by clicking More Styles on the very right of the ribbon. Sincerely, Nettie, BillionDigital Team
JPa
Ok thank you...
Are these styles the as default for whole wordpreess web site as defaults .. from which all others are inherited ??
Ok thank you... Are these styles the as default for whole wordpreess web site as defaults .. from which all others are inherited ??
Yes. Additionally, you can style separate controls and and sections in a different way if you wish.
Hello, Yes. Additionally, you can style separate controls and and sections in a different way if you wish. Sincerely, Nettie, BillionDigital Team
JPa
Hi Nettie....
I understand ... .
When I go style set up (look to attached picture) red marks ....
There I can find -- Inherit (Theme: H2: 14px)
But I wand to set up these Theme: styles(text: H1-H6: .... fonts, color, size, ... ) from which i is inherited ...
but where can find this set up
It means I want to change default theme styles Theme: Text, Theme: H1-H6, Theme: ... others ....
From these will be inherited by all others ...
Hope you understand now ...
JURAJ
Hi Nettie.... I understand ... . When I go style set up (look to attached picture) red marks .... There I can find -- **Inherit (Theme: H2: 14px)** But I wand to set up these **Theme: styles**(text: H1-H6: .... fonts, color, size, ... ) from which i is inherited ... but where can find this set up It means I want to change default theme styles Theme: Text, Theme: H1-H6, Theme: ... others .... From these will be inherited by all others ... Hope you understand now ... JURAJ
If you change Headings in the way you provided on the screenshot:
All headings on your website will use these settings. These are default theme heading settings.
Heading itself inherits size from basic text size, but the same size is inherited by other headings and text elements.
Hi, If you change Headings in the way you provided on the screenshot: !default-headings.png! All headings on your website will use these settings. These are default theme heading settings. Heading itself inherits size from basic text size, but the same size is inherited by other headings and text elements. Thank you, Olivia
