Artisteer Templates
Amiel
Amiel posted this 25 August 2014
I would to know if all Artisteer templates function the same as the built in templates, meaning:
1. RTL / LTR
2. Responsive layouts.
How are your templates installed in Artisteer?
will your templates support Artisteer 4.3?
Amiel
Hi, I would to know if all Artisteer templates function the same as the built in templates, meaning: 1. RTL / LTR 2. Responsive layouts. How are your templates installed in Artisteer? will your templates support Artisteer 4.3? Thank you, Amiel
Support Team posted this 25 August 2014
Hello Amiel,
all Artisteer templates support the responsive mode and RTL/LTR text directions.
You may enable these options under File >> Export >> Options >> General
I suppose you mean the Artisteer themes downloaded from http://templates.themler.com/
They all are compatible with Artisteer 4.3, just open them with v. 4.3.
Hello Amiel, all Artisteer templates support the responsive mode and RTL/LTR text directions. You may enable these options under File >> Export >> Options >> General I suppose you mean the Artisteer themes downloaded from http://templates.themler.com/ They all are compatible with Artisteer 4.3, just open them with v. 4.3. Regards, Aileen
