strange message in wordpress
lavisbre
lavisbre posted this 19 December 2017
the odd message in wordpress
if the image doesnt work then go here and look https://image.ibb.co/miXy26/Fire_Shot_Capture_2_Dashboard_SEO_Inbound_Marketing_http_seo_inbound_marketing_com_wp_admin.png
ok so I had my site removed and a freash install of wordpress on the server.
I made a wordpress theam in themlar.
I installed the theam with no plugins
the above images is there saying warning: inet_pton()
What is this and why, please? this is what appeared on my last site and it was broken
![the odd message in wordpress][1] [1]: https://ibb.co/gMBEaR if the image doesnt work then go here and look https://image.ibb.co/miXy26/Fire_Shot_Capture_2_Dashboard_SEO_Inbound_Marketing_http_seo_inbound_marketing_com_wp_admin.png ok so I had my site removed and a freash install of wordpress on the server. I made a wordpress theam in themlar. I installed the theam with no plugins the above images is there saying warning: inet_pton() What is this and why, please? this is what appeared on my last site and it was broken
lavisbre
So the new site has no SSL attached, I make the change to the SSl licence and get this error messege
https://image.ibb.co/gvpEQR/changed_http_to_https_and_got_this_error.png
error
can you advise what i must do please?
do i change to Https in wordpress ?
So the new site has no SSL attached, I make the change to the SSl licence and get this error messege https://image.ibb.co/gvpEQR/changed_http_to_https_and_got_this_error.png ![error][1] [1]: https://image.ibb.co/gvpEQR/changed_http_to_https_and_got_this_error.png can you advise what i must do please? do i change to Https in wordpress ?
Support Team posted this 19 December 2017
Please check that both addresses (WP address and Site address) in the Settings >> General in your WP admin are using the same protocol.
Hi, Please check that both addresses (WP address and Site address) in the Settings >> General in your WP admin are using the same protocol. Sincerely, Hella
lavisbre
https://image.ibb.co/fyoHx6/setting.png
both say http://seo-inbound-marketing.com and http://seo-inbound-marketing.com
should it be https://
https://image.ibb.co/fyoHx6/setting.png both say http://seo-inbound-marketing.com and http://seo-inbound-marketing.com should it be https://
Support Team posted this 20 December 2017
Yes, please try to set them to https and see if that helps.
Hi, Yes, please try to set them to `https` and see if that helps. Sincerely, Hella
lavisbre
lavisbre posted this 21 December 2017
yeh it did thanks
yeh it did thanks
Support Team posted this 21 December 2017
lavisbre
thank you
thank you
