Sub Menu Expands along with the header section
Webnoesys IT Solutions LLP
Webnoesys IT Solutions LLP posted this 3 weeks ago
Dear Sir,
URL - http://tbasheergovtkhazi.webnoesys.com/Contact_Us.html
1) The menu is expanding when click on it along with the header section. Can we avoid this if yes then how ?
And in main page its not expending, but in other pages its expanding as said above.
2) Can we change the menu icon and hover icon. If yes, then how ?
Kindly find the screenshot of the same.
Suffian Ahmed
Dear Sir, URL - http://tbasheergovtkhazi.webnoesys.com/Contact_Us.html 1) The menu is expanding when click on it along with the header section. Can we avoid this if yes then how ? And in main page its not expending, but in other pages its expanding as said above. 2) Can we change the menu icon and hover icon. If yes, then how ? Kindly find the screenshot of the same. Regards Suffian Ahmed
10 Comments
  1. Choose the Mobile Menu >> Action to be Popup on Click.
  2. Under the Mobile Menu drop down choose the Hover option and change to the desired one.
Hi, 1. Choose the Mobile Menu >> Action to be Popup on Click. 2. Under the Mobile Menu drop down choose the Hover option and change to the desired one. Sincerely, Hella
Webnoesys IT Solutions LLP posted this 2 weeks ago
Dear Hella,
Prefect answer.... Thank you.
And, can we get icon on horizontal menu like one icon on every root sub menu which has child menus and also as we hover on each sub menu under main menu i like to show the icon on hover.
Is that possible. ???
Icons for sub menu root and sub menu icons should display only on hover of the sub menu.
Suffian Ahmed
Dear Hella, Prefect answer.... Thank you. And, can we get icon on horizontal menu like one icon on every root sub menu which has child menus and also as we hover on each sub menu under main menu i like to show the icon on hover. Is that possible. ??? Icons for sub menu root and sub menu icons should display only on hover of the sub menu. Regards Suffian Ahmed
Webnoesys IT Solutions LLP posted this 1 weeks ago
Dear Hella,
Please kindly update us the below query too along with the above one.
How to make horizontal menu open or flip from right or left.
For example - http://www.sabkadentist.com/
This menu on click on it open side window from right or left. I need the same kind.
We have used it for our template example - http://tbasheergovtkhazi.webnoesys.com
I need the above Website horizontal menu with side window open. How to achieve this, please help us to make it possible.
I know there are some options in Themler, I tried but its not working. So, need your support please.
Waiting for your valuable reply,
Thanks in advance,
Suffian Ahmed
Dear Hella, Please kindly update us the below query too along with the above one. How to make horizontal menu open or flip from right or left. For example - http://www.sabkadentist.com/ This menu on click on it open side window from right or left. I need the same kind. We have used it for our template example - http://tbasheergovtkhazi.webnoesys.com I need the above Website horizontal menu with side window open. How to achieve this, please help us to make it possible. I know there are some options in Themler, I tried but its not working. So, need your support please. Waiting for your valuable reply, Thanks in advance, Regards Suffian Ahmed
I do not completely understand this part:
If you need the icon to be displayed on the hover state only, then you can set the icon color to transparent and set the desired color for the hover state only.
I do not see the flip effect, maybe some screen shot will be helpful. If you mean that you press the menu button and it opens the menu on the left side like this: https://www.jqueryscript.net/demo/Slick-App-Like-Sliding-Menu-Plugin-With-jQuery-Mmenu/examples/tutorial/page.html ? That is not possible in Themler, you will need some external plug-ins.
Hi, I do not completely understand this part: >And, can we get icon on horizontal menu like one icon on every root sub menu which has child menus and also as we hover on each sub menu under main menu i like to show the icon on hover. If you need the icon to be displayed on the hover state only, then you can set the icon color to transparent and set the desired color for the hover state only. >How to make horizontal menu open or flip from right or left. For example - http://www.sabkadentist.com/ I do not see the flip effect, maybe some screen shot will be helpful. If you mean that you press the menu button and it opens the menu on the left side like this: https://www.jqueryscript.net/demo/Slick-App-Like-Sliding-Menu-Plugin-With-jQuery-Mmenu/examples/tutorial/page.html ? That is not possible in Themler, you will need some external plug-ins. Sincerely, Hella
Hello Hella,
Please find the screenshot attached as requested.
Its in mobile version, i need it for desktop and mobile version too...
Suffian Ahmed
Hello Hella, Please find the screenshot attached as requested. Its in mobile version, i need it for desktop and mobile version too... Regards Suffian Ahmed
No, this is not possible in Themler.
No, this is not possible in Themler. Sincerely, Hella
OK, how click event works in your menu... As i said, we have used it under http://tbasheergovtkhazi.webnoesys.com/
But, we are not getting any script which controls click event of the same icon. Check the screenshot attached...
Can we look in to the script so that we can understand it and control it using any third party script etc...
Suffian Ahmed
OK, how click event works in your menu... As i said, we have used it under http://tbasheergovtkhazi.webnoesys.com/ But, we are not getting any script which controls click event of the same icon. Check the screenshot attached... Can we look in to the script so that we can understand it and control it using any third party script etc... Regards Suffian Ahmed
And one more query, how to implement hover hover out transaction effects.
Right now, themler supports hover in for all events / animations like rotate, zoom in out, flips, slider in/out etc etc. All works or animates only on mouse hover in. But, mouse hover out is not there. Can we make it possible using any third party with your existing css styles... ???
Find the screenshot attached for our understanding... And sample link http://fortius.webnoesys.net/ (Check in the footer, the QR Code is rotating on mouse hover in, but hover out effect we required too. How to make it possible ???
Mouse In & Out are animating in the below link. But, in Themler only In is there. And, out is not there. Why ?
Demo FYI - https://codepen.io/dangvanthanh/pen/EKDut
And, second query, can we get slider scrolling / dragging using our mouse ???
Suffian Ahmed
And one more query, how to implement hover hover out transaction effects. Right now, themler supports hover in for all events / animations like rotate, zoom in out, flips, slider in/out etc etc. All works or animates only on mouse hover in. But, mouse hover out is not there. Can we make it possible using any third party with your existing css styles... ??? Find the screenshot attached for our understanding... And sample link http://fortius.webnoesys.net/ (Check in the footer, the QR Code is rotating on mouse hover in, but hover out effect we required too. How to make it possible ??? Mouse In & Out are animating in the below link. But, in Themler only In is there. And, out is not there. Why ? Demo FYI - https://codepen.io/dangvanthanh/pen/EKDut And, second query, can we get slider scrolling / dragging using our mouse ??? Regards Suffian Ahmed
Webnoesys IT Solutions LLP posted this 6 days ago
And, one more query the smooth scrolling is not working even we initiated the smoth scrolling settings in the below web sites.
http://fortius.webnoesys.net/home.html
Is there any value we need to make it to acheive the smooth scrolling ???
Suffian Ahmed
And, one more query the smooth scrolling is not working even we initiated the smoth scrolling settings in the below web sites. http://fortius.webnoesys.net/home.html http://tbasheergovtkhazi.webnoesys.com Is there any value we need to make it to acheive the smooth scrolling ??? Regards Suffian Ahmed
Sorry for the delay.
It is in bootstrap.min.js file. Themler uses regular bootstrap menu.
Unfortunately Animation extension does not have hover out trigger action.
Do you mean the Smooth Wheel effect that can be enabled under the Themler Home tab >> Settings?
It does not work in Chrome because Chrome blocks the library commonly used for this effect.
Hi, Sorry for the delay. > Can we look in to the script so that we can understand it and control it using any third party script etc... It is in bootstrap.min.js file. Themler uses regular bootstrap menu. Unfortunately Animation extension does not have hover out trigger action. > And, one more query the smooth scrolling is not working even we initiated the smoth scrolling settings in the below web sites. Do you mean the Smooth Wheel effect that can be enabled under the Themler Home tab >> Settings? It does not work in Chrome because Chrome blocks the library commonly used for this effect. Thank you, Olivia
