pages working as one single site wide page
lavisbre
lavisbre posted this 28 December 2017
enter image description here
Do you notice on the left in WP i have header all templates and a header.
now template page has a section that is blank.
now to the right do you see section above the bread crumbs.
This is the third time i have deleted a blood site and re made it. i have clean WP installs and the only thing left is themlar.
What problem this is causing is every page duplicates itself with content across all pages but the homepage.
I add a widget to page 2 and it apears on 3 / 4 / 5 and six
i add a form to page 6 and it remove the widget and speads accross page 2 /3 /4 /5 and six
What do youthink is going on please
![enter image description here][1] [1]: https://image.ibb.co/g3bhrb/nightmare.png Do you notice on the left in WP i have header all templates and a header. now template page has a section that is blank. now to the right do you see section above the bread crumbs. This is the third time i have deleted a blood site and re made it. i have clean WP installs and the only thing left is themlar. What problem this is causing is every page duplicates itself with content across all pages but the homepage. I add a widget to page 2 and it apears on 3 / 4 / 5 and six i add a form to page 6 and it remove the widget and speads accross page 2 /3 /4 /5 and six What do youthink is going on please
Support Team posted this 28 December 2017
Please check the following article about templates in Themler themes:
http://answers.themler.io/articles/36359/how-to-work-with-templates-in-wordpress-themes
Themler does not create pages. Pages and Posts should be creates in CMS. Themler creates templates which are applied to the CMS pages:
  • Page Template for ALL WP pages
  • Post Template for ALL WP posts
The blue area is an area of a template. The element added to this area will be located on the template and appear on all pages which use this template.
In order to edit the content of the opened page please make sure that CMS content is enabled under the Design tab. When the content is enabled you should see the green area which is an area of the content.
Hello, Please check the following article about templates in Themler themes: http://answers.themler.io/articles/36359/how-to-work-with-templates-in-wordpress-themes Themler does not create pages. Pages and Posts should be creates in CMS. Themler creates templates which are applied to the CMS pages: - Page Template for ALL WP pages - Post Template for ALL WP posts The blue area is an area of a template. The element added to this area will be located on the template and appear on all pages which use this template. In order to edit the content of the opened page please make sure that CMS content is enabled under the Design tab. When the content is enabled you should see the green area which is an area of the content. Please let us know if you have any further questions. Thank you, Olivia
lavisbre
Thank you, for some reason this was all on yet no green area?
I turned it off and on again and it shows the green area.
Now im trying to add a custom widget in the green area and its takes it, i then open WP and add custom HTML and save and it takes it.
I open my site and it wont show?
just has random text
So I add it to the blue add control which works and throws it over all pages?
![enter image description here][1]Thank you, for some reason this was all on yet no green area? I turned it off and on again and it shows the green area. Now im trying to add a custom widget in the green area and its takes it, i then open WP and add custom HTML and save and it takes it. I open my site and it wont show? just has random text ![enter image description here][2] So I add it to the blue add control which works and throws it over all pages? [1]: https://image.ibb.co/jUMyzw/widget_error.png [2]: https://image.ibb.co/eAXozw/widget_has_content.png
Support Team posted this 31 December 2017
Widget area is an area for WP Widgets. Green area is an area of the WP Page or Post. WP does тещ allows to insert widgets into te content of posts or pages. Therefore Widget area control will not work inside green area. You can insert it on the blue template level or into the orange area of the header, Footer or Sidebars.
Hi, Widget area is an area for WP Widgets. Green area is an area of the WP Page or Post. WP does тещ allows to insert widgets into te content of posts or pages. Therefore Widget area control will not work inside green area. You can insert it on the blue template level or into the orange area of the header, Footer or Sidebars. Please keep us posted about the progress. Thank you, Olivia
