Themler installation problem or bug?
whiley
whiley posted this 04 January 2018
I've downloades themler desktopversion foe windows yesterday (3. January 2018) and have installed it on a win 7 PC.
I open themler with Jommla. At the "?" it shows me that themler v319 is installed ?
But:
If i want to update, a popup with an error-message appears:
Die Webseite unter https://themler.com/designer/Account/ExternalLogOn?returnUrl=%2fProfileData ist möglicherweise vorübergehend nicht verfügbar oder wurde dauerhaft an eine neue Webadresse verschoben.
I get the same error-message if I want to import a theme, if I want to save a theme, if I want to export a theme ....
Whats going wrong?
regards
Whiley
I've downloades themler desktopversion foe windows yesterday (3. January 2018) and have installed it on a win 7 PC. I open themler with Jommla. At the "?" it shows me that themler **v319** is installed ? But: If i want to update, a popup with an error-message appears: ***Die Webseite unter https://themler.com/designer/Account/ExternalLogOn?returnUrl=%2fProfileData ist möglicherweise vorübergehend nicht verfügbar oder wurde dauerhaft an eine neue Webadresse verschoben.*** I get the same error-message if I want to import a theme, if I want to save a theme, if I want to export a theme .... Whats going wrong? regards Whiley
Support Team posted this 05 January 2018
The login functionality works just fine on my side. Does the issue continue on your side?
Hi, The login functionality works just fine on my side. Does the issue continue on your side? Thank you, Olivia
whiley
whiley posted this 05 January 2018
Hi Olivia,
I've tried it in this moment and the issue still exists.
I can't update, save, import and export
regards
Whiley
Hi Olivia, I've tried it in this moment and the issue still exists. I can't update, save, import and export regards Whiley
Support Team posted this 06 January 2018
Hello Whiley,
Does the issue persist at the moment? Could you try temporarily disabling antivirus, firewall and other third-party applications and also browser add-ons, and try with anothery browser?
Hello Whiley, Does the issue persist at the moment? Could you try temporarily disabling antivirus, firewall and other third-party applications and also browser add-ons, and try with anothery browser? Sincerely, Nettie, BillionDigital Team
